<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stick (gray) usb power from code]]></title><description><![CDATA[<p dir="auto">Hi all, is it possible to know if the power comes from the usb cable from code on M5Stick (gray)?</p>
<p dir="auto">tnks a lot</p>
]]></description><link>https://community.m5stack.com/topic/1233/m5stick-gray-usb-power-from-code</link><generator>RSS for Node</generator><lastBuildDate>Sat, 27 Jun 2026 07:54:03 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1233.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 18 Aug 2019 07:31:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stick (gray) usb power from code on Wed, 28 Aug 2019 23:41:10 GMT]]></title><description><![CDATA[<p dir="auto">this is my solution:</p>
<pre><code>
#include &lt;M5Stack.h&gt;
#include &lt;U8g2lib.h&gt;
uint8_t bat = M5.Power.getBatteryLevel();
U8G2_SH1107_64X128_1_4W_HW_SPI u8g2(U8G2_R1, /* cs=*/ 14, /* dc=*/ 27, /* reset=*/ 33);
void setup(void) {
  M5.begin();
  Wire.begin();
  u8g2.begin();
  Serial.begin(9600);
void loop(void) {
  delay(500);
  Batteria();
void Batteria() {//
  u8g2.firstPage();
  do {
    if (M5.Power.isCharging()) {
      // DEBUG Serial.println("Battery is charging");
      u8g2.setFont(u8g2_font_battery19_tn);
      u8g2.drawGlyph(2, 20, 48);
      u8g2.setFont(u8g2_font_unifont_t_symbols);
      u8g2.drawGlyph(1, 16, 8623); //fulmine
    } else {
      u8g2.drawGlyph(2, 20, 48); // VUOTA
      if (bat &gt; 50) {
        u8g2.drawGlyph(2, 20, 49); // una tacca
      if (bat &gt; 100) {
        u8g2.drawGlyph(2, 20, 50); // //due tacche
      if (bat &gt; 150) {
        u8g2.drawGlyph(2, 20, 51); // tre tacche
      if (bat &gt; 200) {
        u8g2.drawGlyph(2, 20, 52); // quattro tacche
      if (bat &gt; 250) {
        u8g2.drawGlyph(2, 20, 53); // cinque tacche
    /// FOR DEBUG/////
    //u8g2.setFont(u8g2_font_7Segments_26x42_mn);
    //u8g2.setCursor(20, 52);
    //u8g2.print(bat);
    //Serial.print(bat);
    //Serial.println(" %");
  } while ( u8g2.nextPage() );
<p dir="auto">right now.....</p>
]]></description><link>https://community.m5stack.com/post/5359</link><guid isPermaLink="true">https://community.m5stack.com/post/5359</guid><dc:creator><![CDATA[cepics]]></dc:creator><pubDate>Wed, 28 Aug 2019 23:41:10 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stick (gray) usb power from code on Mon, 19 Aug 2019 20:26:50 GMT]]></title><description><![CDATA[<p dir="auto">Yes I'm asking exactly this arduino code but for M5Stick GRAY (NOT C)</p>
<p dir="auto">tnks a lot..</p>
]]></description><link>https://community.m5stack.com/post/5246</link><guid isPermaLink="true">https://community.m5stack.com/post/5246</guid><dc:creator><![CDATA[cepics]]></dc:creator><pubDate>Mon, 19 Aug 2019 20:26:50 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stick (gray) usb power from code on Mon, 19 Aug 2019 02:37:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/cepics" aria-label="Profile: cepics">@<bdi>cepics</bdi></a> I presume your asking for code to check whether the usb is inserted or not, what the current flow over usb, battery charge amount etc. You didn't specify which programming language you wanted the code in. If your using Arduino this code may help you.</p>
<pre><code>#include &lt;M5StickC.h&gt;
  // put your setup code here, to run once:
  M5.begin();
  M5.Lcd.fillScreen(BLACK);
  M5.Axp.EnableCoulombcounter();
double vbat = 0.0;
double discharge,charge;
double temp = 0.0;
double bat_p = 0.0;
double bat_p2 = 0.0;
  vbat      = M5.Axp.GetVbatData() * 1.1 / 1000;
  charge    = M5.Axp.GetIchargeData() / 2.0 / 1000;
  discharge = M5.Axp.GetIdischargeData() / 2.0 / 1000;
  temp      =  -144.7 + M5.Axp.GetTempData() * 0.1;
  bat_p     =  M5.Axp.GetPowerbatData() * 1.1 * 0.5 /1000 /1000;
  M5.Lcd.setCursor(0, 0, 1);
  M5.Lcd.printf("vbat   :%.2fV\r\n",vbat);
  M5.Lcd.printf("icharge:%.2fA\r\n",charge);
  M5.Lcd.printf("idischg:%.2fA\r\n",discharge);
  M5.Lcd.printf("temp   :%3.1fC\r\n",temp);
  M5.Lcd.printf("pbat   :%.2fW\r\n",bat_p);
  M5.Lcd.printf("CoIn   :%5d\r\n",M5.Axp.GetCoulombchargeData());
  M5.Lcd.printf("CoOut  :%5d\r\n",M5.Axp.GetCoulombdischargeData());
  M5.Lcd.printf("CoD    :%.2f\r\n",M5.Axp.GetCoulombData());
  M5.Lcd.printf("          mAh\r\n");
  M5.Lcd.printf("Vin    :%.2fV\r\n",M5.Axp.GetVinData() * 1.7 /1000);
  M5.Lcd.printf("Iin    :%.2fA\r\n",M5.Axp.GetIinData() * 0.625 /1000);
  M5.Lcd.printf("Vusbin :%.2fV\r\n",GetVusbinData() * 1.7 /1000);
  M5.Lcd.printf("Iusbin :%.2fA\r\n",GetIusbinData() * 0.375 /1000);
  M5.Lcd.printf("VAPS   :%.2fV\r\n", GetVapsData()*1.4/1000);
  M5.Lcd.printf("WL     :%5d\r\n",GetWarningLeve());
  delay(1000);
uint16_t GetVusbinData(void){
    uint16_t vin = 0;
    Wire1.beginTransmission(0x34);
    Wire1.write(0x5a);
    Wire1.endTransmission();
    Wire1.requestFrom(0x34, 1);
    uint8_t buf = Wire1.read();
    Wire1.write(0x5b);
    uint8_t buf2 = Wire1.read();
    vin = ((buf &lt;&lt; 4) + buf2); // V
    return vin;
uint16_t GetIusbinData(void){
    uint16_t iin = 0;
    Wire1.write(0x5c);
    Wire1.write(0x5d);
    iin = ((buf &lt;&lt; 4) + buf2); // V
    return iin;
uint16_t GetVapsData(void){
    uint16_t vaps = 0;
    Wire1.write(0x7E);
    Wire1.write(0x7F);
    vaps = ((uint16_t)(buf &lt;&lt; 4) + buf2);
    return vaps;
uint8_t GetWarningLeve(void){
    uint16_t vaps = 0;
    Wire1.write(0x47);
    return (buf &amp;amp; 0x01);
}</code></pre>
]]></description><link>https://community.m5stack.com/post/5221</link><guid isPermaLink="true">https://community.m5stack.com/post/5221</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Mon, 19 Aug 2019 02:37:01 GMT</pubDate></item></channel></rss>
