<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[All my M5Stack&#x2F;Stick sketch doesn&#x27;t compile anymore]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
after some test with FACES firmware on my osx machine following <a href="https://docs.m5stack.com/#/en/quick_start/faces/gameboy_burn_a_nes_game?id=download-firmware" target="_blank" rel="noopener noreferrer nofollow ugc">this</a> doc and upgrade M5stack library, now I can't verify/compile NONE of my M5Stack/Stick sketch.</p>
<p dir="auto">Error compiling for board M5Stack-Core-ESP32.</p>
<p dir="auto">this is the arduino IDE output:</p>
<pre><code>Arduino: 1.8.9 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
/Users/ce/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp: In member function 'void POWER::powerOFF()':
/Users/ce/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp:361:28: error: 'gpio_deep_sleep_hold_dis' was not declared in this scope
   gpio_deep_sleep_hold_dis();
Multiple libraries were found for "SPI.h"
 Used: /Users/ce/Documents/Arduino/hardware/espressif/esp32/libraries/SPI
 Not used: /Users/ce/Documents/Arduino/libraries/SPI
Multiple libraries were found for "SD.h"
 Used: /Users/ce/Documents/Arduino/hardware/espressif/esp32/libraries/SD
 Not used: /Users/ce/Documents/Arduino/libraries/SD
 Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/A5F0A3E3-D38F-48FA-A88D-47CA921F1A87/d/Arduino-1.8.9.app/Contents/Java/libraries/SD
Multiple libraries were found for "WiFi.h"
 Used: /Users/ce/Documents/Arduino/hardware/espressif/esp32/libraries/WiFi
 Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/A5F0A3E3-D38F-48FA-A88D-47CA921F1A87/d/Arduino-1.8.9.app/Contents/Java/libraries/WiFi
Multiple libraries were found for "RunningMedian.h"
 Used: /Users/ce/Documents/Arduino/libraries/RunningMedian
 Not used: /Users/ce/Documents/Arduino/libraries/RunningMedianOLD
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -&gt; Preferences.
<p dir="auto">(the other sketch for arduino mega and Uno compile normally)</p>
<p dir="auto">Please Help</p>
<p dir="auto">tnks a lot</p>
]]></description><link>https://community.m5stack.com/topic/1261/all-my-m5stack-stick-sketch-doesn-t-compile-anymore</link><generator>RSS for Node</generator><lastBuildDate>Sat, 27 Jun 2026 07:54:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1261.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Aug 2019 21:57:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to All my M5Stack&#x2F;Stick sketch doesn&#x27;t compile anymore on Tue, 10 Sep 2019 02:12:43 GMT]]></title><description><![CDATA[<p dir="auto">solved on commenting out</p>
<p dir="auto">gpio_deep_sleep_hold_dis();</p>
<p dir="auto">in</p>
<p dir="auto">Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp</p>
<p dir="auto">I don't know why, but now arduino compile</p>
]]></description><link>https://community.m5stack.com/post/5545</link><guid isPermaLink="true">https://community.m5stack.com/post/5545</guid><dc:creator><![CDATA[cepics]]></dc:creator><pubDate>Tue, 10 Sep 2019 02:12:43 GMT</pubDate></item><item><title><![CDATA[Reply to All my M5Stack&#x2F;Stick sketch doesn&#x27;t compile anymore on Thu, 29 Aug 2019 17:43:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cepics" aria-label="Profile: cepics">@<bdi>cepics</bdi></a> said in <a href="/post/5328">All my M5Stack/Stick sketch doesn't compile anymore</a>:</p>
<p dir="auto">Multiple libraries were found for "SPI.h"<br />
Used: /Users/ce/Documents/Arduino/hardware/espressif/esp32/libraries/SPI<br />
Not used: /Users/ce/Documents/Arduino/libraries/SPI</p>
<p dir="auto">You have installed multiple libraries</p>
<p dir="auto">This report would have more information with<br />
"Show verbose output during compilation"<br />
option enabled in File -&gt; Preferences.</p>
<p dir="auto">Use the option "Show verbose output during compilation", as shown in the compiler message, to get more information about the problem.</p>
]]></description><link>https://community.m5stack.com/post/5375</link><guid isPermaLink="true">https://community.m5stack.com/post/5375</guid><dc:creator><![CDATA[Gaviota]]></dc:creator><pubDate>Thu, 29 Aug 2019 17:43:59 GMT</pubDate></item></channel></rss>
