<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CoreMP135 screen saver sleep for built in LCD]]></title><description><![CDATA[<p dir="auto">Is there a way to enable sleep for built in LCD to<br />
turn it off to conserve power and turn on/wake up by touch?</p>
<p dir="auto">I’m using Debian image.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/6644/coremp135-screen-saver-sleep-for-built-in-lcd</link><generator>RSS for Node</generator><lastBuildDate>Wed, 24 Jun 2026 11:41:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6644.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Jul 2024 18:09:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CoreMP135 screen saver sleep for built in LCD on Sat, 20 Jul 2024 18:12:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/25880">CoreMP135 screen saver sleep for built in LCD</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mgrouch" aria-label="Profile: mgrouch">@<bdi>mgrouch</bdi></a> You need to create a program for that</p>
<p dir="auto">I do not see how. There are examples for displaying things on ILI9342C<br />
using framebuffer and LVGL.<br />
I do not see how to turn off backlight on ILI9342C. Is there some code example? Or command line utility with the code to control brightness? I was able to code that on m5stack tough on esp32 which has same ILI9342C.</p>
<p dir="auto">Also how to wake up screen by touch?<br />
I guess with brightness off touch functions are still there. So I need example of code listening for touch event and controlling backlight (voltage of it?) on ILI9342C.</p>
<p dir="auto">I need some help.<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/post/25895</link><guid isPermaLink="true">https://community.m5stack.com/post/25895</guid><dc:creator><![CDATA[mgrouch]]></dc:creator><pubDate>Sat, 20 Jul 2024 18:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to CoreMP135 screen saver sleep for built in LCD on Thu, 18 Jul 2024 19:37:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mgrouch" aria-label="Profile: mgrouch">@<bdi>mgrouch</bdi></a> You need to create a program for that</p>
]]></description><link>https://community.m5stack.com/post/25880</link><guid isPermaLink="true">https://community.m5stack.com/post/25880</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 18 Jul 2024 19:37:39 GMT</pubDate></item></channel></rss>
