<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Relay on I2C port cause M5Go to restart.]]></title><description><![CDATA[<p dir="auto">I'm testing the relay on Port A as its listed as a digital I/O port.<br />
When triggered the relay works fine but when it releases the M5Go restarts.<br />
Is this just me or an issue with the relay module.</p>
]]></description><link>https://community.m5stack.com/topic/891/relay-on-i2c-port-cause-m5go-to-restart</link><generator>RSS for Node</generator><lastBuildDate>Fri, 26 Jun 2026 23:10:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/891.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Apr 2019 13:17:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Relay on I2C port cause M5Go to restart. on Fri, 26 Apr 2019 12:53:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5-docs" aria-label="Profile: m5-docs">@<bdi>m5-docs</bdi></a> <a href="https://electronics.stackexchange.com/questions/115857/flyback-diodes-and-relays" target="_blank" rel="noopener noreferrer nofollow ugc">https://electronics.stackexchange.com/questions/115857/flyback-diodes-and-relays</a></p>
]]></description><link>https://community.m5stack.com/post/4009</link><guid isPermaLink="true">https://community.m5stack.com/post/4009</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 26 Apr 2019 12:53:01 GMT</pubDate></item><item><title><![CDATA[Reply to Relay on I2C port cause M5Go to restart. on Fri, 26 Apr 2019 12:48:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5-docs" aria-label="Profile: m5-docs">@<bdi>m5-docs</bdi></a> said in <a href="/post/4007">Relay on I2C port cause M5Go to restart.</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Can I know the source of your picture?</p>
<p dir="auto">Sorry, Gimme a sec to find it. Its a common diagram of the flyback/bypass diodes connected in relay modules</p>
]]></description><link>https://community.m5stack.com/post/4008</link><guid isPermaLink="true">https://community.m5stack.com/post/4008</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 26 Apr 2019 12:48:29 GMT</pubDate></item><item><title><![CDATA[Reply to Relay on I2C port cause M5Go to restart. on Fri, 26 Apr 2019 12:45:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Can I know the source of your picture?</p>
]]></description><link>https://community.m5stack.com/post/4007</link><guid isPermaLink="true">https://community.m5stack.com/post/4007</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 26 Apr 2019 12:45:16 GMT</pubDate></item><item><title><![CDATA[Reply to Relay on I2C port cause M5Go to restart. on Fri, 26 Apr 2019 12:43:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks a lot !</p>
]]></description><link>https://community.m5stack.com/post/4006</link><guid isPermaLink="true">https://community.m5stack.com/post/4006</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 26 Apr 2019 12:43:34 GMT</pubDate></item><item><title><![CDATA[Reply to Relay on I2C port cause M5Go to restart. on Wed, 24 Apr 2019 08:51:17 GMT]]></title><description><![CDATA[<p dir="auto">heres an image showing the flyback/bypass diode missing from the relay<br />
<img src="https://i.stack.imgur.com/Gwm1y.png" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/3976</link><guid isPermaLink="true">https://community.m5stack.com/post/3976</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 24 Apr 2019 08:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to Relay on I2C port cause M5Go to restart. on Wed, 24 Apr 2019 01:53:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> the support operator?</p>
]]></description><link>https://community.m5stack.com/post/3965</link><guid isPermaLink="true">https://community.m5stack.com/post/3965</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Wed, 24 Apr 2019 01:53:51 GMT</pubDate></item><item><title><![CDATA[Reply to Relay on I2C port cause M5Go to restart. on Tue, 23 Apr 2019 11:36:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5-docs" aria-label="Profile: m5-docs">@<bdi>m5-docs</bdi></a> I sent the diagrams to the support operator.<br />
It is fine on the I/O port (B) but on A it cause the trip. I am worried that this could cause premature failure of io pins.</p>
]]></description><link>https://community.m5stack.com/post/3952</link><guid isPermaLink="true">https://community.m5stack.com/post/3952</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 23 Apr 2019 11:36:27 GMT</pubDate></item><item><title><![CDATA[Reply to Relay on I2C port cause M5Go to restart. on Tue, 23 Apr 2019 11:34:33 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>,</p>
<p dir="auto">I remembered the question you said.</p>
<p dir="auto">Anti-back charge diode.</p>
<p dir="auto">Is it convenient for you to give detailed information? Especially the photos</p>
]]></description><link>https://community.m5stack.com/post/3951</link><guid isPermaLink="true">https://community.m5stack.com/post/3951</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Tue, 23 Apr 2019 11:34:33 GMT</pubDate></item><item><title><![CDATA[Reply to Relay on I2C port cause M5Go to restart. on Wed, 17 Apr 2019 13:20:52 GMT]]></title><description><![CDATA[<p dir="auto">Ok its missing the back feed diode.</p>
]]></description><link>https://community.m5stack.com/post/3800</link><guid isPermaLink="true">https://community.m5stack.com/post/3800</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 17 Apr 2019 13:20:52 GMT</pubDate></item></channel></rss>
