<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to connect the INMP441 (I2S microphone) to the M5Stack?]]></title><description><![CDATA[<p dir="auto">Hello everyone.<br />
I´m doubt about which pins to use to connect the INMP441.<br />
How to connect the components?<br />
There are no I2S pins in ESP32. Instead, I need to set / enable the pins in code.<br />
All examples use the I2S-MEMS to the following ESP32 pins:</p>
<li>SEL is unconnected, i.e. only one channel, apparently left</li>
<li>LRCL to #15</li>
<li>DOUT to #32</li>
<li>BCKL to #14</li>
<li>GND to GND</li>
<li>3V to 3V</li>
]]></description><link>https://community.m5stack.com/topic/1021/how-to-connect-the-inmp441-i2s-microphone-to-the-m5stack</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 22:33:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1021.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 May 2019 15:41:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to connect the INMP441 (I2S microphone) to the M5Stack? on Fri, 15 Nov 2019 22:32:48 GMT]]></title><description><![CDATA[<p dir="auto">I know I'm late to the game but I just bought one of these. Did you ever manage to connect it to your m5stack <a class="plugin-mentions-user plugin-mentions-a" href="/user/dfabro" aria-label="Profile: dfabro">@<bdi>dfabro</bdi></a> ? if not I'm gonna try, and if I'm successful will post my findings here</p>
]]></description><link>https://community.m5stack.com/post/6383</link><guid isPermaLink="true">https://community.m5stack.com/post/6383</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Fri, 15 Nov 2019 22:32:48 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect the INMP441 (I2S microphone) to the M5Stack? on Thu, 23 May 2019 14:30:01 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your help.<br />
M5Stack ESP32 MPU9250<br />
<a href="https://www.banggood.com/INMP441-Omnidirectional-Microphone-I2S-Interface-Digital-Output-Sensor-Module-Supports-ESP32-p-1401405.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.banggood.com/INMP441-Omnidirectional-Microphone-I2S-Interface-Digital-Output-Sensor-Module-Supports-ESP32-p-1401405.html</a></p>
]]></description><link>https://community.m5stack.com/post/4413</link><guid isPermaLink="true">https://community.m5stack.com/post/4413</guid><dc:creator><![CDATA[dfabro]]></dc:creator><pubDate>Thu, 23 May 2019 14:30:01 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect the INMP441 (I2S microphone) to the M5Stack? on Wed, 22 May 2019 16:10:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dfabro" aria-label="Profile: dfabro">@<bdi>dfabro</bdi></a> said in <a href="/post/4399">How to connect the INMP441 (I2S microphone) to the M5Stack?</a>:</p>
<p dir="auto">INMP441<br />
Technically all pins in an ESP32 are I2S.<br />
Because of the amount of functions packed into the chip selecting pins and functions are separate things.<br />
What M5Stack are you using?<br />
What model INMP441 are you using as the pinouts dont match anything I can find.</p>
]]></description><link>https://community.m5stack.com/post/4400</link><guid isPermaLink="true">https://community.m5stack.com/post/4400</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 22 May 2019 16:10:50 GMT</pubDate></item></channel></rss>
