<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC internal battery disconnection]]></title><description><![CDATA[<p dir="auto">Is there a way to disconnect the internal battery of the M5StickC so it will be only on when power is supplied to USB-C plug?<br />
Cutting a wire?</p>
]]></description><link>https://community.m5stack.com/topic/1039/m5stickc-internal-battery-disconnection</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 21:42:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1039.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 May 2019 14:48:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC internal battery disconnection on Thu, 30 May 2019 07:40:48 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, the structure inside the device is totally fixed. It is not easy to disassemble it and keep the hardware good. Instead of charging the hardware side, do you prefer to program the power management IC and change the power supply priority?  Details refer to the AXP192.</p>
]]></description><link>https://community.m5stack.com/post/4477</link><guid isPermaLink="true">https://community.m5stack.com/post/4477</guid><dc:creator><![CDATA[liushasha]]></dc:creator><pubDate>Thu, 30 May 2019 07:40:48 GMT</pubDate></item></channel></rss>
