<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding external libraries via uiflow]]></title><description><![CDATA[<p dir="auto">I am trying to use BNO055 but cant add the library.<br />
Put the line import adafruit_bno055 inside an execute block but receive error. How can I add external libraries? Can anyone help?</p>
]]></description><link>https://community.m5stack.com/topic/1056/adding-external-libraries-via-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:01:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1056.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Jun 2019 11:51:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adding external libraries via uiflow on Sat, 20 Jun 2020 09:17:19 GMT]]></title><description><![CDATA[<p dir="auto">If you use Visual Code you could install this extension</p>
<p dir="auto"><a href="https://marketplace.visualstudio.com/items?itemName=curdeveryday.vscode-m5stack-mpy" target="_blank" rel="noopener noreferrer nofollow ugc">https://marketplace.visualstudio.com/items?itemName=curdeveryday.vscode-m5stack-mpy</a></p>
<p dir="auto">Then transfer your modified library to flash. It would be good to change the name to another one, so that the import function does not load the built-in urequests library. Alternatively, you would have to look in what order and from which locations the libraries are imported.</p>
]]></description><link>https://community.m5stack.com/post/9066</link><guid isPermaLink="true">https://community.m5stack.com/post/9066</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Sat, 20 Jun 2020 09:17:19 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Sat, 20 Jun 2020 08:15:09 GMT]]></title><description><![CDATA[<p dir="auto">UIFlow is based on Micropython 1.11 so switching isn't that hard.<br />
Check out <a href="https://www.youtube.com/channel/UCozgFVglWYQXbvTmGyS739w" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/channel/UCozgFVglWYQXbvTmGyS739w</a> luke made a useful vid on it.</p>
<p dir="auto">The great thing about UIFlow/Micropython is that you can build most of the program in UIFlow and then switch to Micropython to make final adjustments.<br />
The only issue is that you can't change back to UIFlow after adjusting because the code blocks won't exist for you added code.</p>
]]></description><link>https://community.m5stack.com/post/9065</link><guid isPermaLink="true">https://community.m5stack.com/post/9065</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 20 Jun 2020 08:15:09 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Sat, 20 Jun 2020 07:20:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/9062">Adding external libraries via uiflow</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jesuslg123" aria-label="Profile: jesuslg123">@<bdi>jesuslg123</bdi></a> If you use a programs like VStudio, Thonny and mu that you can add library directly to the M5Stack</p>
<p dir="auto">Thanks, for the this project I was using the UIFlow editor with the UI programming language, do you think I can also replace the urequest version that is using this?<br />
Also can you share with me how to upload with Visual Studio? Thanks</p>
]]></description><link>https://community.m5stack.com/post/9064</link><guid isPermaLink="true">https://community.m5stack.com/post/9064</guid><dc:creator><![CDATA[jesuslg123]]></dc:creator><pubDate>Sat, 20 Jun 2020 07:20:26 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Sat, 20 Jun 2020 05:44:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jesuslg123" aria-label="Profile: jesuslg123">@<bdi>jesuslg123</bdi></a> If you use a programs like VStudio, Thonny and mu that you can add library directly to the M5Stack</p>
]]></description><link>https://community.m5stack.com/post/9062</link><guid isPermaLink="true">https://community.m5stack.com/post/9062</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 20 Jun 2020 05:44:42 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Fri, 19 Jun 2020 21:26:46 GMT]]></title><description><![CDATA[<p dir="auto">Is this method valid to replace libraries like <code>urequests</code>? I found a "bug" on the current implementation and I would like to replace the one that comes with the UIFlow firmware to workaround the issue. Is that possible or in any other way?<br />
Thanks!</p>
]]></description><link>https://community.m5stack.com/post/9059</link><guid isPermaLink="true">https://community.m5stack.com/post/9059</guid><dc:creator><![CDATA[jesuslg123]]></dc:creator><pubDate>Fri, 19 Jun 2020 21:26:46 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Thu, 20 Feb 2020 16:33:23 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, world101, for your quick response.<br />
Now Blynk works at my M5STACK.<br />
Your Blynk.m5b has five UiFlow blocks for only three virtual functions.<br />
But Blynk offers much more features.<br />
Has anyone already generated more UiFLOW blocks they can share?</p>
]]></description><link>https://community.m5stack.com/post/7511</link><guid isPermaLink="true">https://community.m5stack.com/post/7511</guid><dc:creator><![CDATA[ATU]]></dc:creator><pubDate>Thu, 20 Feb 2020 16:33:23 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Sun, 16 Feb 2020 20:32:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/atu" aria-label="Profile: atu">@<bdi>atu</bdi></a> said in <a href="/post/7429">Adding external libraries via uiflow</a>:</p>
<p dir="auto">Hello, world101 I am very new here in the forum and want to control my M5STACK with "blynk" via UIflow symbols.<br />
I use:<br />
UiFlow V1.4.3<br />
F5STACK fire, the red one.<br />
blynk for Python v0.2.1 (esp32_LoBo)<br />
MicroPython ESP32_LoBo_v3.2.24 - 2018-09-06 on M5Stack with ESP32</p>
<p dir="auto">I have successfully worked through all the above points.<br />
However, the dispaly from my M5STACK shows the following error message:</p>
<p dir="auto">error<br />
ImportError("no module named 'uiflow'",)</p>
<p dir="auto">I think that I have not installed the above mentioned elements:<br />
"machine, time, m5base, uiflow"</p>
<p dir="auto">In the <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a> I have edited the following, as you have described above:<br />
import sys<br />
sys.path.append('flowlib/lib')<br />
sys.path.append('/flash/blynk')<br />
import machine, time, m5base, uiflow, BlynkLib</p>
<p dir="auto">I would like to implement remote monitoring via iphon of my groundwater pump.<br />
It would be nice if you could help me, please.</p>
<p dir="auto">You’re not going to (easily) be able to use LoBo Micropython and the later versions of UIFlow. I think uiFlow v1.2.3 was the latest that LoBo was supported. Best thing would be to flash the official v1.4.4 firmware from M5Stack and use uiFlow v1.4.4.</p>
<p dir="auto">Try that first, then try to import the Blynk libs and see if it works.</p>
]]></description><link>https://community.m5stack.com/post/7439</link><guid isPermaLink="true">https://community.m5stack.com/post/7439</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 16 Feb 2020 20:32:00 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Sun, 16 Feb 2020 14:51:39 GMT]]></title><description><![CDATA[<p dir="auto">Hello, world101 I am very new here in the forum and want to control my M5STACK with "blynk" via UIflow symbols.<br />
I use:<br />
UiFlow V1.4.3<br />
import sys<br />
]]></description><link>https://community.m5stack.com/post/7429</link><guid isPermaLink="true">https://community.m5stack.com/post/7429</guid><dc:creator><![CDATA[ATU]]></dc:creator><pubDate>Sun, 16 Feb 2020 14:51:39 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Tue, 02 Jul 2019 14:28:54 GMT]]></title><description><![CDATA[<p dir="auto">By the way, you should be able to follow a similar procedure to load any custom library. Just create the directory /flash/custom and then reference it with sys.path.append('/flash/custom') in <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a>.</p>
<pre><code>ampy -p /dev/tty.SLAB_USBtoUART -b 115200 mkdir /flash/custom
ampy -p /dev/tty.SLAB_USBtoUART -b 115200 put customLib.py /flash/custom/customLib.py
<p dir="auto">in <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a>:</p>
<pre><code>import sys
<p dir="auto">Then with uiFlow, you can use the execute block to have the choice when it gets imported (so you don't import it automatically when your program doesn't need it).<br />
<img src="/assets/uploads/files/1562066485571-screen-shot-2019-07-02-at-7.20.47-am.png" alt="0_1562066480425_Screen Shot 2019-07-02 at 7.20.47 AM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/4751</link><guid isPermaLink="true">https://community.m5stack.com/post/4751</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Tue, 02 Jul 2019 14:28:54 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Tue, 02 Jul 2019 11:25:59 GMT]]></title><description><![CDATA[<p dir="auto">I just got Blynk working again with the latest 0.2.0 release from Github.</p>
<pre><code>git clone https://github.com/vshymanskyy/blynk-library-python.git
cd blynk-library-python
ampy -p /dev/tty.SLAB_USBtoUART -b 115200 mkdir /flash/blynk
ampy -p /dev/tty.SLAB_USBtoUART -b 115200 put BlynkLib.py /flash/blynk/BlynkLib.py
ampy -p /dev/tty.SLAB_USBtoUART -b 115200 get /flash/boot.py &gt; boot.py
<p dir="auto">Use vi to edit the first few lines of <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a> to look like this:</p>
<p dir="auto">Copy the modified <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a> back to the m5stack:</p>
<pre><code>ampy -p /dev/tty.SLAB_USBtoUART -b 115200 put boot.py /flash/boot.py
<p dir="auto">Connect to the serial interface via screen and reboot the m5stack. You should see the Blynk lib load at bootup.</p>
<pre><code>Internal FS (FatFS): Mounted on partition 'internalfs' [size: 2162688; Flash address: 0x1F0000]
Filesystem size: 2101248 B
           Used: 1409024 B
           Free: 692224 B
I (413) [TFTSPI]: attached display device, speed=8000000
I (413) [TFTSPI]: bus uses native pins: false
W (1296) sdspi_host: spi bus changed (1 -&gt; 2)
[ M5 ] init sd card Fail
[ M5 ] node id:30aea449cd9c, api key:1CAA42CC
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ for Python v0.2.0 (esp32)
I (2284) modsocket: Initializing
I (7288) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (7392) phy: phy_version: 4100, 2a5dd04, Jan 23 2019, 21:00:07, 0, 0
<p dir="auto">Reference thread:  <a href="http://forum.m5stack.com/topic/575/blynk-on-m5stack-via-uiflow-and-block-maker" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/575/blynk-on-m5stack-via-uiflow-and-block-maker</a></p>
]]></description><link>https://community.m5stack.com/post/4750</link><guid isPermaLink="true">https://community.m5stack.com/post/4750</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Tue, 02 Jul 2019 11:25:59 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Tue, 02 Jul 2019 04:44:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a> said in <a href="/post/4746">Adding external libraries via uiflow</a>:</p>
<p dir="auto">Since m5stack moved from the Loboris fork of Micropython to the official Micropython v1.11 release, it seems the libs were also moved somewhere. With m5stack firmware v1.2.x, they used to be in /flash/lib, however now with firmware 1.3.x, that directory does not exist. If I try to create /flash/lib with ampy, the m5stack won't boot properly.</p>
           Used: 1400832 B
           Free: 700416 B
  File "boot.py", line 4, in &lt;module&gt;
  File "flowlib/uiflow.py", line 1, in &lt;module&gt;
  File "flowlib/m5stack.py", line 5, in &lt;module&gt;
ImportError: no module named 'lib.speak'
  File "main.py", line 17, in &lt;module&gt;
NameError: name 'rgb' isn't defined
MicroPython v1.11-112-g5f3c6ee93-dirty on 2019-06-26; ESP32 module with ESP32
&gt;&gt;&gt;
<p dir="auto">The above serial output during bootup shows something in flowlib, but I can't seem to access it. If someone could assist with where to put the custom libs, I could probably get Blynk working again.</p>
<p dir="auto">I thought that was just me. I too tried to copy over blynk this weekend using vstudio but again had the same boot issue.</p>
]]></description><link>https://community.m5stack.com/post/4748</link><guid isPermaLink="true">https://community.m5stack.com/post/4748</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 02 Jul 2019 04:44:48 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Tue, 02 Jul 2019 01:55:47 GMT]]></title><description><![CDATA[<p dir="auto">UIFLOW most lib post in <a href="https://github.com/m5stack/UIFlow-Code" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/UIFlow-Code</a>, wiki have some api</p>
]]></description><link>https://community.m5stack.com/post/4747</link><guid isPermaLink="true">https://community.m5stack.com/post/4747</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Tue, 02 Jul 2019 01:55:47 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Tue, 02 Jul 2019 01:47:22 GMT]]></title><description><![CDATA[<p dir="auto">Since m5stack moved from the Loboris fork of Micropython to the official Micropython v1.11 release, it seems the libs were also moved somewhere. With m5stack firmware v1.2.x, they used to be in /flash/lib, however now with firmware 1.3.x, that directory does not exist. If I try to create /flash/lib with ampy, the m5stack won't boot properly.</p>
           Used: 1400832 B
           Free: 700416 B
&gt;&gt;&gt;
]]></description><link>https://community.m5stack.com/post/4746</link><guid isPermaLink="true">https://community.m5stack.com/post/4746</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Tue, 02 Jul 2019 01:47:22 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Tue, 02 Jul 2019 01:18:21 GMT]]></title><description><![CDATA[<p dir="auto">As far as I know the Uiflow Micropython source is not available yet. Some others have posted guides on how to flash alternative micropython builds with other libraries <a href="https://www.hackster.io/andreas-motzek/execute-logo-on-m5stack-esp32-basic-with-micropython-3713fd" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.hackster.io/andreas-motzek/execute-logo-on-m5stack-esp32-basic-with-micropython-3713fd</a><br />
You could try creating your own spiffs image to include the libraries you need<br />
<a href="https://github.com/igrr/mkspiffs" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/igrr/mkspiffs</a> although I haven't tried this yet and not sure if you have to add anything extra to make the uiflow firmware recognize the spiffs partition</p>
]]></description><link>https://community.m5stack.com/post/4742</link><guid isPermaLink="true">https://community.m5stack.com/post/4742</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Tue, 02 Jul 2019 01:18:21 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Mon, 01 Jul 2019 12:02:08 GMT]]></title><description><![CDATA[<p dir="auto">Is there a tutorial somewhere on how to build the UI-Flow Firmware?<br />
Would like to add some libraries, like for example paho-mqtt, and I think it would be best to build a custom FW for that.<br />
<a href="https://github.com/EeeeBin/UIFlow-Firmware" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/EeeeBin/UIFlow-Firmware</a>, referenced from <a href="https://github.com/m5stack/M5Stack-Firmware" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Stack-Firmware</a> only offers binaries.</p>
<p dir="auto">Not sure whether <a href="https://github.com/m5stack/M5Stack_MicroPython" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Stack_MicroPython</a> includes UI-Flow.</p>
<p dir="auto">Any pointers?</p>
]]></description><link>https://community.m5stack.com/post/4739</link><guid isPermaLink="true">https://community.m5stack.com/post/4739</guid><dc:creator><![CDATA[romor001]]></dc:creator><pubDate>Mon, 01 Jul 2019 12:02:08 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Sun, 16 Jun 2019 13:14:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>  Thanks hope a built in block comes in the future</p>
]]></description><link>https://community.m5stack.com/post/4648</link><guid isPermaLink="true">https://community.m5stack.com/post/4648</guid><dc:creator><![CDATA[hetzer]]></dc:creator><pubDate>Sun, 16 Jun 2019 13:14:05 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Sun, 16 Jun 2019 10:17:00 GMT]]></title><description><![CDATA[<p dir="auto">I have tried looking into this today but having trouble getting repl to run. <a class="plugin-mentions-user plugin-mentions-a" href="/user/hetzer" aria-label="Profile: hetzer">@<bdi>hetzer</bdi></a>  I have not forgotten about your issue, I have just been too busy to look much into it.</p>
]]></description><link>https://community.m5stack.com/post/4645</link><guid isPermaLink="true">https://community.m5stack.com/post/4645</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 16 Jun 2019 10:17:00 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Fri, 07 Jun 2019 21:38:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> said in <a href="/post/4555">Adding external libraries via uiflow</a>:</p>
<p dir="auto">th blynk. Have you tried putting the module on to the flash more than once? I've found ampy to be a little buggy at times, sometimes the copy wasn't successful sometimes it was.</p>
<p dir="auto">Yes, flashed it couple of times and also tried by transferring the file via upyLoader. Same result. Blynk is very easy to use and it would be great with the convenience of uiflow and M5stack.</p>
]]></description><link>https://community.m5stack.com/post/4560</link><guid isPermaLink="true">https://community.m5stack.com/post/4560</guid><dc:creator><![CDATA[hetzer]]></dc:creator><pubDate>Fri, 07 Jun 2019 21:38:31 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Fri, 07 Jun 2019 19:19:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> Yeh, <a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a> had a lib working but I haven't had time to work with it in ages. been having issues with my in house server.</p>
]]></description><link>https://community.m5stack.com/post/4556</link><guid isPermaLink="true">https://community.m5stack.com/post/4556</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 07 Jun 2019 19:19:45 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Fri, 07 Jun 2019 17:04:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> weren't you an world101 able to do some stuff with blynk. Have you tried putting the module on to the flash more than once? I've found ampy to be a little buggy at times, sometimes the copy wasn't successfull sometimes it was.</p>
]]></description><link>https://community.m5stack.com/post/4555</link><guid isPermaLink="true">https://community.m5stack.com/post/4555</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Fri, 07 Jun 2019 17:04:02 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Thu, 06 Jun 2019 15:29:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a>  I followed the instructions, copied the blynklib into flash/lib folder but receiving the following error:<br />
AttributeError("module object has no attribute Blynk",)</p>
]]></description><link>https://community.m5stack.com/post/4548</link><guid isPermaLink="true">https://community.m5stack.com/post/4548</guid><dc:creator><![CDATA[hetzer]]></dc:creator><pubDate>Thu, 06 Jun 2019 15:29:01 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Thu, 06 Jun 2019 01:40:22 GMT]]></title><description><![CDATA[<p dir="auto">Seems ampy is not working in 1.3.1, I recommend firmware 1.2.2 or 1.2.3 if you want to transfer files via ampy you can check these two videos on our channel for getting started <a href="https://www.youtube.com/watch?v=rvP3GixWG1Y&amp;t=109s" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=rvP3GixWG1Y&amp;t=109s</a> and <a href="https://www.youtube.com/watch?v=V67MY-1ccqM" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=V67MY-1ccqM</a></p>
]]></description><link>https://community.m5stack.com/post/4541</link><guid isPermaLink="true">https://community.m5stack.com/post/4541</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 06 Jun 2019 01:40:22 GMT</pubDate></item><item><title><![CDATA[Reply to Adding external libraries via uiflow on Tue, 04 Jun 2019 16:30:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hetzer" aria-label="Profile: hetzer">@<bdi>hetzer</bdi></a> this function is not presently available in uiflow blocky.<br />
You need to write the library to the m5 stack in a terminal onto the m5 stack before you call it using ampy from adafruit.</p>
]]></description><link>https://community.m5stack.com/post/4530</link><guid isPermaLink="true">https://community.m5stack.com/post/4530</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 04 Jun 2019 16:30:49 GMT</pubDate></item></channel></rss>
