<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Replacement parts]]></title><description><![CDATA[<p dir="auto">unfortunately the power button broke of my M5 (of the pcb) when pressing it on.<br />
Tried to repair this but I failed. Anybody here with the same problem.<br />
Currently uploads do not work. How can I fix it<br />
Is there a  excact list available of parts e.g. were to get a replacement items like micro switch or other parts like the display.</p>
<p dir="auto">thanks</p>
]]></description><link>https://community.m5stack.com/topic/107/replacement-parts</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:40:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/107.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Feb 2018 18:25:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Replacement parts on Fri, 16 Mar 2018 18:50:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1101" aria-label="Profile: chris1101">@<bdi>chris1101</bdi></a><br />
Hi Chris, haven't seen any other reports of this..... I've used quite a few M5's without any button problems.</p>
<p dir="auto">Some parts are referenced on the last page of the info sheet included with the M5 - but not the buttons. Don't think there is another list referencing parts.</p>
<p dir="auto"><strong>In terms of a fix:</strong></p>
<p dir="auto">Presumably the M5 powers on when connected to USB.  So I'm assuming you sometimes need the on/off/reset button to operate as the reset button when you are uploading code. And naturally you need the button to power on the M5 when dis-connected from USB. Is that right?</p>
<p dir="auto">Connecting a capacitor between the RST and GND ports should solve both these problems. Connect negative to ground , positive to RST.</p>
<p dir="auto">When NOT connected to USB, connecting the cap should power it up (can remove cap once started**). Also when uploading code, leaving it connected should allow code to load - or if use of the reset button is needed when uploading, just disconnect and re-connect the cap. Or - connect a button along with the cap.</p>
<p dir="auto">The cap I use is a 22 uf through-hole cap with polarity. 10 uf max has been suggested as the ideal max - but I've had no problems.</p>
<p dir="auto">Further discussion re. which cap to use:<br />
<a href="http://forum.m5stack.com/topic/113/an-even-simpler-fix-when-upload-fails" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/113/an-even-simpler-fix-when-upload-fails</a><br />
<a href="http://forum.m5stack.com/topic/55/simple-fix-when-upload-fails/24" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/55/simple-fix-when-upload-fails/24</a></p>
<p dir="auto">** Turning it off could still be a problem.</p>
]]></description><link>https://community.m5stack.com/post/447</link><guid isPermaLink="true">https://community.m5stack.com/post/447</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Fri, 16 Mar 2018 18:50:02 GMT</pubDate></item></channel></rss>
