<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rotate UI object]]></title><description><![CDATA[<p dir="auto">Is it possible to rotate a UI object to a set angle?</p>
]]></description><link>https://community.m5stack.com/topic/1079/rotate-ui-object</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 13:37:56 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1079.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Jun 2019 01:09:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rotate UI object on Mon, 08 Jul 2019 04:43:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brett" aria-label="Profile: brett">@<bdi>brett</bdi></a> do you want to rotate the whole display or simply some of the graphic elements? As <a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> stated the rotation option is available for the text label, but elements such as the rectangle or triangle graphic elements are not rotatable due to the module they are based on not supporting this feature.</p>
]]></description><link>https://community.m5stack.com/post/4770</link><guid isPermaLink="true">https://community.m5stack.com/post/4770</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Mon, 08 Jul 2019 04:43:09 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate UI object on Thu, 04 Jul 2019 18:02:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brett" aria-label="Profile: brett">@<bdi>brett</bdi></a> said in <a href="/post/4759">Rotate UI object</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> I see an option to rotate a polygon under LCD.polygon, but I'm not seeing a GUI object rotation angle. Could you explain further?</p>
<p dir="auto">Thanks</p>
<p dir="auto">When you add a label from the five icons above the Virtual M5Stack, a rotation block will appear in the UI Drop down menu.</p>
]]></description><link>https://community.m5stack.com/post/4760</link><guid isPermaLink="true">https://community.m5stack.com/post/4760</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 04 Jul 2019 18:02:35 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate UI object on Thu, 04 Jul 2019 17:49:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> I see an option to rotate a polygon under LCD.polygon, but I'm not seeing a GUI object rotation angle. Could you explain further?</p>
]]></description><link>https://community.m5stack.com/post/4759</link><guid isPermaLink="true">https://community.m5stack.com/post/4759</guid><dc:creator><![CDATA[brett]]></dc:creator><pubDate>Thu, 04 Jul 2019 17:49:01 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate UI object on Thu, 13 Jun 2019 04:28:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brett" aria-label="Profile: brett">@<bdi>brett</bdi></a> with the 1.3.2 branch of UIFlow there is now the option to set a GUI object rotation angle.</p>
]]></description><link>https://community.m5stack.com/post/4615</link><guid isPermaLink="true">https://community.m5stack.com/post/4615</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 13 Jun 2019 04:28:35 GMT</pubDate></item></channel></rss>
