<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Ui Flow on iPad (almost neat...) useful if your iPad is the only piece of technology at hand...]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">If you have the misfortune to open uiflow on your iPad browser and wondered what to do with the amazing blocky script just created here is a few tips to make good use of the time spent (works on iOS 12.3.1):<br />
1 don’t close the browser or refresh the page<br />
2 select uiflow menu and then Save<br />
3 on safari the screen changes to a json-like script<br />
4 select all of it and in the contextual menu select ‘Share’<br />
5 the pop up icons menu appears<br />
6 choose ‘Save as’<br />
7 select a location /folder you know iOS can access from its Files app (usually Pages, Numbers or other iOS friendly folder, avoid app exclusive areas)<br />
8 save it<br />
9 open the app Files<br />
10 navigate to the folder<br />
11 find the file and rename with the name you prefer plus a .m5f at the end<br />
12 the script is now safe<br />
13 if you get again to uiflow you can open the script from its menu (it is visible to uiflow now that you changed the file extension)<br />
14 modify and save as above</p>
<p dir="auto">Enjoy!!</p>
]]></description><link>https://community.m5stack.com/topic/1105/ui-flow-on-ipad-almost-neat-useful-if-your-ipad-is-the-only-piece-of-technology-at-hand</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:02:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1105.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Jun 2019 20:44:11 GMT</pubDate><ttl>60</ttl></channel></rss>
