<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Products 05-July 2019 And new video series.]]></title><description><![CDATA[<p dir="auto">New Products 05-July-2019 in <a href="https://m5stack.aliexpress.com/store/new-arrivals/3226069.html?spm=a2g0o.detail.1000061.5.7e015809opellZ" target="_blank" rel="noopener noreferrer nofollow ugc">Offical M5Stack Aliexpress store.</a><br />
After all this time, research and testing the MKV Camera is now available.<br />
<a href="https://www.aliexpress.com/item/33053936438.html?storeId=3226069&amp;spm=2114.12010611.8148356.33.480a25dczUW7RG" target="_blank" rel="noopener noreferrer nofollow ugc">MKV K210 AI Risc-V Camera</a><br />
<img src="https://ae01.alicdn.com/kf/HTB1xc0RXXT7gK0jSZFpq6yTkpXam/M5Stack-New-Arrival-StickV-K210-AI-Camera-64-BIT-RISC-V-MPU6886-Chip-with-16M-Flash.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
M5Stick-V RISC-V AI Camera</p>
<p dir="auto">General Description<br />
M5Stack recently launched the new AIOT(AI+IOT) Camera powered by Kendryte K210 -an edge computing system-on-chip(SoC) with dual-core 64bit RISC-V CPU and state-of-art neural network processor.</p>
<p dir="auto">M5stick-V AI Camera features its integration with machine vision capabilities, featuring the unprocessed acceptability to AI Visioning with high energy efficiency and low cost. We co-oped with Sipeed providing the MicroPython environment makes programming onM5stick-V easier.</p>
<p dir="auto">The module comes with the OmniVision OV7740 sensor, using the OmniPixel®3-HS technology, providing a best-in-class low light sensitivity, making it ideal for machine vision. In addition to an OV7740 sensor, M5stick-V features more hardware resources such as a speaker with built-in I2S Class-D DAC, MEMS Microphone, IPS screen, 6-axis IMU, 200mAh Li-po battery, and more.</p>
<p dir="auto">More than the visioning, M5stick-V also features the embedded APU - Audio Processor. With its hardware beam-forming support and dual 512-point FFT units, the M5stick-V is also capable of a series of machine hearing works like voice wake-up to speech recognition.</p>
<p dir="auto">Features:<br />
Dual-Core 64-bit RISC-V RV64IMAFDC (RV64GC) CPU / 400Mhz(Normal)<br />
Dual Independent Double Precision FPU<br />
8MiB 64bit width On-Chip SRAM<br />
Neural Network Processor(KPU) / 0.8Tops<br />
Field-Programmable IO Array (FPIOA)<br />
Dual hardware 512-point 16bit Complex FFT<br />
SPI, I2C, UART, I2S, RTC, PWM, Timer Support<br />
AES, SHA256 Accelerator<br />
Direct Memory Access Controller (DMAC)<br />
Micropython Support<br />
Firmware encryption support<br />
On-board Hardware resources:<br />
Flash: 16M.<br />
TFT: ST7789. 135*240 IPS 1.14 SPI<br />
Camera :OV7740<br />
PCM: MAX98357<br />
PMIC: AXP192<br />
Button: Front and side.<br />
Battery: 200mAh.<br />
Indicator light: RGBW .<br />
External storage: TF card/Micro SD<br />
Microphone: MSM261S4030HOR.<br />
Gyro: MPU6886.<br />
Interface: CONNEXT .</p>
<p dir="auto">A Laser Transmitter</p>
<p dir="auto">Laser TX](<a href="https://www.aliexpress.com/item/33054016613.html?storeId=3226069&amp;spm=2114.12010611.8148356.37.480a25dcfKhGXl" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.aliexpress.com/item/33054016613.html?storeId=3226069&amp;spm=2114.12010611.8148356.37.480a25dcfKhGXl</a>)<br />
<img src="https://ae01.alicdn.com/kf/HTB1kNd8Xhv1gK0jSZFFq6z0sXXar/M5Stack-official-Laser-Tx-Unit-Laser-Emitter-With-Adjustable-Focal-Length.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">A Laser reciever.<br />
<a href="https://www.aliexpress.com/item/33057050935.html?storeId=3226069&amp;spm=2114.12010611.8148356.39.480a25dcslh7kR" target="_blank" rel="noopener noreferrer nofollow ugc">Laser RX</a><br />
<img src="https://ae01.alicdn.com/kf/HTB1BSX9XbY1gK0jSZTEq6xDQVXaj/M5Stack-official-Laser-Rx-Unit-non-modulation-Laser-receiver-Laser-Transistor.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Mini Proto<br />
<a href="https://www.aliexpress.com/item/33054016465.html?storeId=3226069&amp;spm=2114.12010611.8148356.35.480a25dcI1OkKg" target="_blank" rel="noopener noreferrer nofollow ugc">link text</a><br />
<img src="https://ae01.alicdn.com/kf/HTB1pMl7XoY1gK0jSZFMq6yWcVXa1/M5Stack-Mini-Proto-Board-Unit-Prototyping-2-54mm-PCB-Grove-Port-Compatible-ESP32-Development-Kit-Accept.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">ADC Hat<br />
<a href="https://www.aliexpress.com/item/33054032667.html?storeId=3226069&amp;spm=2114.12010611.8148356.41.480a25dcCnhKy8" target="_blank" rel="noopener noreferrer nofollow ugc">ADC Hat</a><br />
<img src="https://ae01.alicdn.com/kf/HTB1FVx_XhD1gK0jSZFKq6AJrVXaY/M5StickC-ESP32Mini-IoT-Development-Board-Finger-Computer-Compatible-ADC-HAT-ADS1100.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">DAC Hat<br />
<a href="https://www.aliexpress.com/item/33057975803.html?storeId=3226069&amp;spm=2114.12010611.8148356.43.480a25dczzcCDB" target="_blank" rel="noopener noreferrer nofollow ugc">DAC Hat</a><br />
<img src="https://ae01.alicdn.com/kf/HTB1z6B6Xa67gK0jSZFHq6y9jVXaY/M5StickC-ESP32Mini-IoT-Development-Board-Finger-Computer-Compatible-DAC-HAT-MCP4725.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">RS485 Hat<br />
<a href="https://www.aliexpress.com/item/33057086268.html?storeId=3226069&amp;spm=2114.12010611.8148356.45.480a25dcLco9qK" target="_blank" rel="noopener noreferrer nofollow ugc">RS485 Hat</a><br />
<img src="https://ae01.alicdn.com/kf/HTB19MV.XbY1gK0jSZTEq6xDQVXaM/M5StickC-ESP32Mini-IoT-Development-Board-Finger-Computer-Compatible-RS485-HAT-AOZ1282CI.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">To accompany these new items, <a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus89" aria-label="Profile: lukasmaximus89">@<bdi>lukasmaximus89</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> has now created a video.<br />
<a href="https://www.youtube.com/watch?v=el1corcD-to" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=el1corcD-to</a></p>
]]></description><link>https://community.m5stack.com/topic/1121/new-products-05-july-2019-and-new-video-series</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 23:49:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1121.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Jul 2019 17:11:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Products 05-July 2019 And new video series. on Fri, 05 Jul 2019 18:21:28 GMT]]></title><description><![CDATA[<p dir="auto">One can only assume that its because the risc V doesn't have built in wifi.</p>
]]></description><link>https://community.m5stack.com/post/4765</link><guid isPermaLink="true">https://community.m5stack.com/post/4765</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 05 Jul 2019 18:21:28 GMT</pubDate></item><item><title><![CDATA[Reply to New Products 05-July 2019 And new video series. on Fri, 05 Jul 2019 17:52:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a><br />
No WiFi on the M5StickV.... why???</p>
]]></description><link>https://community.m5stack.com/post/4764</link><guid isPermaLink="true">https://community.m5stack.com/post/4764</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Fri, 05 Jul 2019 17:52:12 GMT</pubDate></item></channel></rss>
