<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ENV hat support UI-FLOW for M5StickC]]></title><description><![CDATA[<p dir="auto">I'm new user, purchased a M5StickC and ENV hat, but I cannot see the HAT series can found in UNIT from the UI-FLOW</p>
]]></description><link>https://community.m5stack.com/topic/1123/env-hat-support-ui-flow-for-m5stickc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 05:05:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1123.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jul 2019 16:26:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ENV hat support UI-FLOW for M5StickC on Thu, 26 Sep 2019 08:34:51 GMT]]></title><description><![CDATA[<p dir="auto">My env hat just arrived. Did some testing and guess what?</p>
<p dir="auto">Same problem. "Env hat maybe not connect"</p>
<p dir="auto">Env hat is working on a new stick that came with a band, does not work with another one from a previous batch.</p>
<p dir="auto">In general my observation is as follows, with band far better quality, then without it... And I cannot accept that, that's not serious enough for my purposes, name using the sticks in teaching.</p>
<p dir="auto">I can see that the additional board on that stick is soldered askew. Hilariously askew... I wonder which pin is broken, some, all? Where is the code that determines that "maybe not connect"?</p>
<p dir="auto">So yeah, there are major quality problems. When it rains with these sticks, it pours. I mean defects.</p>
<p dir="auto">Don't look for the problem in the users. We are not that dumb.</p>
<p dir="auto">Still have to check each and every one of my sticks for a bunch of problems. That's time consuming, aggravated additionally by half baked tools... So disappointing, that I keep postponing that painful task, I am not a masochist.</p>
<p dir="auto">Wanted to get impressed, but based on what I got, did not happen...</p>
]]></description><link>https://community.m5stack.com/post/5737</link><guid isPermaLink="true">https://community.m5stack.com/post/5737</guid><dc:creator><![CDATA[illusion]]></dc:creator><pubDate>Thu, 26 Sep 2019 08:34:51 GMT</pubDate></item><item><title><![CDATA[Reply to ENV hat support UI-FLOW for M5StickC on Sat, 17 Aug 2019 14:47:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tymchn" aria-label="Profile: tymchn">@<bdi>tymchn</bdi></a> said in <a href="/post/5200">ENV hat support UI-FLOW for M5StickC</a>:</p>
<p dir="auto">I am also new to the M5StickC and using UIFlow 1.3.5 Beta and firmware.<br />
I have added the ENV hat as suggested but when I try to read the values and display them with a label I get the following error;</p>
<p dir="auto">ENV hat maybe not connect</p>
<p dir="auto">It's definitely plugged in though.</p>
<p dir="auto">what is your code ?</p>
]]></description><link>https://community.m5stack.com/post/5201</link><guid isPermaLink="true">https://community.m5stack.com/post/5201</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 17 Aug 2019 14:47:39 GMT</pubDate></item><item><title><![CDATA[Reply to ENV hat support UI-FLOW for M5StickC on Sat, 17 Aug 2019 14:29:25 GMT]]></title><description><![CDATA[<p dir="auto">I am also new to the M5StickC and using UIFlow 1.3.5 Beta and firmware.<br />
]]></description><link>https://community.m5stack.com/post/5200</link><guid isPermaLink="true">https://community.m5stack.com/post/5200</guid><dc:creator><![CDATA[tymchn]]></dc:creator><pubDate>Sat, 17 Aug 2019 14:29:25 GMT</pubDate></item><item><title><![CDATA[Reply to ENV hat support UI-FLOW for M5StickC on Wed, 07 Aug 2019 20:24:59 GMT]]></title><description><![CDATA[<p dir="auto">I suggest using UIflow in latest version beta (1.3.5 now) . Click rectangle with roun arrow outside.<br />
With M5Burner upgrade M5StickC firmware to version (1.3.5 now).</p>
]]></description><link>https://community.m5stack.com/post/5064</link><guid isPermaLink="true">https://community.m5stack.com/post/5064</guid><dc:creator><![CDATA[lotron]]></dc:creator><pubDate>Wed, 07 Aug 2019 20:24:59 GMT</pubDate></item><item><title><![CDATA[Reply to ENV hat support UI-FLOW for M5StickC on Tue, 09 Jul 2019 02:39:06 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://flow.m5stack.com/beta/" target="_blank" rel="noopener noreferrer nofollow ugc">http://flow.m5stack.com/beta/</a>  uiflow 1.3.4 support</p>
]]></description><link>https://community.m5stack.com/post/4779</link><guid isPermaLink="true">https://community.m5stack.com/post/4779</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Tue, 09 Jul 2019 02:39:06 GMT</pubDate></item><item><title><![CDATA[Reply to ENV hat support UI-FLOW for M5StickC on Mon, 08 Jul 2019 16:32:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/a2940uw" aria-label="Profile: a2940uw">@<bdi>a2940uw</bdi></a> Are you running the latest UIFlow?<br />
Next to the word UNIT is the Word HAT, click on the word then click on the + to get to the hat list.<br />
I have just tested this!</p>
]]></description><link>https://community.m5stack.com/post/4775</link><guid isPermaLink="true">https://community.m5stack.com/post/4775</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 08 Jul 2019 16:32:38 GMT</pubDate></item></channel></rss>
