<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I cannot upload anything on my M5Stack Fire]]></title><description><![CDATA[<p dir="auto">Hi, can anyone help me?!<br />
I cannot compile anything with the Arduino IDE, due to the the following message:</p>
<p dir="auto">Arduino:1.8.9 (Mac OS X), Scheda:"M5Stack-FIRE, Enabled, 921600, None"</p>
<p dir="auto">/Users/Fabrizio/Documents/Arduino/libraries/M5Stack-master/src/utility/Power.cpp: In member function 'void POWER::powerOFF()':<br />
/Users/Fabrizio/Documents/Arduino/libraries/M5Stack-master/src/utility/Power.cpp:360:35: error: 'ESP_SLEEP_WAKEUP_ALL' was not declared in this scope<br />
esp_sleep_disable_wakeup_source(ESP_SLEEP_WAKEUP_ALL);</p>
<pre><code>                               ^
<p dir="auto">/Users/Fabrizio/Documents/Arduino/libraries/M5Stack-master/src/utility/Power.cpp:361:28: error: 'gpio_deep_sleep_hold_dis' was not declared in this scope<br />
gpio_deep_sleep_hold_dis();</p>
<p dir="auto">What is happening?<br />
I reinstalled the Silicon Labs drivers and the M5Stack library (version 0.2.8) but nothing changed...</p>
<p dir="auto">Thank you very much<br />
Fabrizio</p>
]]></description><link>https://community.m5stack.com/topic/1139/i-cannot-upload-anything-on-my-m5stack-fire</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 08:27:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1139.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Jul 2019 21:15:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I cannot upload anything on my M5Stack Fire on Mon, 30 Mar 2020 10:39:02 GMT]]></title><description><![CDATA[<p dir="auto">Getting same error on all my projects now, I think someting is broken.</p>
]]></description><link>https://community.m5stack.com/post/7964</link><guid isPermaLink="true">https://community.m5stack.com/post/7964</guid><dc:creator><![CDATA[raz0rsedge]]></dc:creator><pubDate>Mon, 30 Mar 2020 10:39:02 GMT</pubDate></item><item><title><![CDATA[Reply to I cannot upload anything on my M5Stack Fire on Tue, 10 Sep 2019 02:14:19 GMT]]></title><description><![CDATA[<p dir="auto">solved on commenting out</p>
<p dir="auto">gpio_deep_sleep_hold_dis();</p>
<p dir="auto">in</p>
<p dir="auto">Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp</p>
<p dir="auto">I don't know why, but now arduino compile</p>
]]></description><link>https://community.m5stack.com/post/5546</link><guid isPermaLink="true">https://community.m5stack.com/post/5546</guid><dc:creator><![CDATA[cepics]]></dc:creator><pubDate>Tue, 10 Sep 2019 02:14:19 GMT</pubDate></item><item><title><![CDATA[Reply to I cannot upload anything on my M5Stack Fire on Wed, 28 Aug 2019 21:17:21 GMT]]></title><description><![CDATA[<p dir="auto">Have you find a solution?</p>
<p dir="auto">same problem here...</p>
<pre><code>Arduino: 1.8.9 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
Invalid library found in /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/AzureIoT: no headers files (.h) found in /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/AzureIoT
Invalid library found in /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/BLE: no headers files (.h) found in /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/BLE
/Users/bip/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp: In member function 'void POWER::powerOFF()':
/Users/bip/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp:361:28: error: 'gpio_deep_sleep_hold_dis' was not declared in this scope
Multiple libraries were found for "SD.h"
 Used: /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/SD
 Not used: /Users/bip/Documents/Arduino/libraries/SD
 Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/A5F0A3E3-D38F-48FA-A88D-47CA921F1A87/d/Arduino-1.8.9.app/Contents/Java/libraries/SD
Multiple libraries were found for "WiFi.h"
 Used: /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/WiFi
 Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/A5F0A3E3-D38F-48FA-A88D-47CA921F1A87/d/Arduino-1.8.9.app/Contents/Java/libraries/WiFi
Multiple libraries were found for "SPI.h"
 Used: /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/SPI
 Not used: /Users/bip/Documents/Arduino/libraries/SPI
exit status 1
Error compiling for board M5Stack-Core-ESP32.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -&gt; Preferences.
<p dir="auto">tnks</p>
]]></description><link>https://community.m5stack.com/post/5357</link><guid isPermaLink="true">https://community.m5stack.com/post/5357</guid><dc:creator><![CDATA[cepics]]></dc:creator><pubDate>Wed, 28 Aug 2019 21:17:21 GMT</pubDate></item><item><title><![CDATA[Reply to I cannot upload anything on my M5Stack Fire on Thu, 18 Jul 2019 21:26:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> I tried to reinstall Arduino IDE 1.8.9 and the library M5Stack, the only one included in my code but nothing changed, always the same error!<br />
Thank you for your help :(</p>
]]></description><link>https://community.m5stack.com/post/4829</link><guid isPermaLink="true">https://community.m5stack.com/post/4829</guid><dc:creator><![CDATA[ferrianf]]></dc:creator><pubDate>Thu, 18 Jul 2019 21:26:42 GMT</pubDate></item><item><title><![CDATA[Reply to I cannot upload anything on my M5Stack Fire on Thu, 18 Jul 2019 04:41:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ferrianf" aria-label="Profile: ferrianf">@<bdi>ferrianf</bdi></a> your arduino install is missing the required librarys needed to compile the code.</p>
]]></description><link>https://community.m5stack.com/post/4824</link><guid isPermaLink="true">https://community.m5stack.com/post/4824</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 18 Jul 2019 04:41:28 GMT</pubDate></item></channel></rss>
