<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Max 5v current out]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm looking to make my own hat for my M5StickC and was looking to find the max current out available at 5v. Any ideas?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/1148/max-5v-current-out</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:01:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1148.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Jul 2019 10:54:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Max 5v current out on Thu, 14 May 2020 16:28:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klimbot" aria-label="Profile: klimbot">@<bdi>klimbot</bdi></a> said in <a href="/post/4864">Max 5v current out</a>:</p>
<p dir="auto">Depending on what kind of hat you are designing, you could design it so that it directly powers you device and supplies power to the stick instead of the stick supply the power.</p>
]]></description><link>https://community.m5stack.com/post/8686</link><guid isPermaLink="true">https://community.m5stack.com/post/8686</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 14 May 2020 16:28:28 GMT</pubDate></item><item><title><![CDATA[Reply to Max 5v current out on Thu, 14 May 2020 13:44:21 GMT]]></title><description><![CDATA[<p dir="auto">Powered by USB:<br />
5V -&gt; 500mA<br />
3.3V -&gt; 500mA</p>
<p dir="auto">Powered by Vin:<br />
5V -&gt; 2000mA<br />
3.3V -&gt; 1200mA</p>
<p dir="auto">You need to subtract the M5Stick's own consumption from these values.</p>
<p dir="auto">M5Stick is using the AXP192 Power management IC, datasheet:<br />
<a href="http://www.x-powers.com/en.php/Info/support/article_id/29" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.x-powers.com/en.php/Info/support/article_id/29</a><br />
M5Stick schematic:<br />
<a href="https://docs.m5stack.com/#/en/core/m5stickc" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/core/m5stickc</a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klimbot" aria-label="Profile: klimbot">@<bdi>klimbot</bdi></a>  probably powered his M5stick via USB.</p>
]]></description><link>https://community.m5stack.com/post/8683</link><guid isPermaLink="true">https://community.m5stack.com/post/8683</guid><dc:creator><![CDATA[Bese]]></dc:creator><pubDate>Thu, 14 May 2020 13:44:21 GMT</pubDate></item><item><title><![CDATA[Reply to Max 5v current out on Thu, 25 Jul 2019 12:22:15 GMT]]></title><description><![CDATA[<p dir="auto">Awesome, thanks for sharing <a class="plugin-mentions-user plugin-mentions-a" href="/user/wikistik" aria-label="Profile: wikistik">@<bdi>wikistik</bdi></a>!!<br />
Will take this in to account when designing my hat.</p>
]]></description><link>https://community.m5stack.com/post/4871</link><guid isPermaLink="true">https://community.m5stack.com/post/4871</guid><dc:creator><![CDATA[klimbot]]></dc:creator><pubDate>Thu, 25 Jul 2019 12:22:15 GMT</pubDate></item><item><title><![CDATA[Reply to Max 5v current out on Wed, 24 Jul 2019 15:41:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klimbot" aria-label="Profile: klimbot">@<bdi>klimbot</bdi></a> Here are some results of practical testing:<br />
Using the 5v header pin with the screen set to black and set to minimum brightness, flashing the led to make sure the cpu was still operating: I could draw about 400ma at the load (fluctuated between 388 and 402 using an incandescent light as a load). This was the case on both USB and battery power.<br />
Using the 5v header pin with the screen displaying some text: the same load drew 500ma but it shut the screen down and the computer did recognize the unit until I replugged it in.</p>
<p dir="auto">So let's say under 400ma with the screen "off" and considerably less with it on.</p>
]]></description><link>https://community.m5stack.com/post/4866</link><guid isPermaLink="true">https://community.m5stack.com/post/4866</guid><dc:creator><![CDATA[wikistik]]></dc:creator><pubDate>Wed, 24 Jul 2019 15:41:27 GMT</pubDate></item></channel></rss>
