<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Gray reboots when USBC power removed]]></title><description><![CDATA[<p dir="auto">Hi all, I have purchased 4 units of M5 Stack, those gray color with MPU9250 to migrate some of my projects. It is a great product. However, what I find to be a showstopper is when I unplug the USB-C cable, the M5 reboots. It does no matter the battery is fully charged or not. The M5 are useless this way as I plan to use in a car, and the USB power comes from a converter using switched 12V wire. All 4 units behaves the same.</p>
<p dir="auto">I would like to know if this is a  IP5306 issue, or a USB DTR/RTS issue. Also the way to fix this.<br />
Without this issue, it is the perfect encased unit for my projects.</p>
]]></description><link>https://community.m5stack.com/topic/1161/m5stack-gray-reboots-when-usbc-power-removed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:45:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1161.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Jul 2019 19:40:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Gray reboots when USBC power removed on Tue, 27 Aug 2019 10:33:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barky919" aria-label="Profile: barky919">@<bdi>barky919</bdi></a> said in <a href="/post/5274">M5Stack Gray reboots when USBC power removed</a>:</p>
<p dir="auto">Thank you, will try today.</p>
<p dir="auto">it works??</p>
]]></description><link>https://community.m5stack.com/post/5315</link><guid isPermaLink="true">https://community.m5stack.com/post/5315</guid><dc:creator><![CDATA[cepics]]></dc:creator><pubDate>Tue, 27 Aug 2019 10:33:22 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray reboots when USBC power removed on Thu, 22 Aug 2019 11:51:48 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, will try today.</p>
]]></description><link>https://community.m5stack.com/post/5274</link><guid isPermaLink="true">https://community.m5stack.com/post/5274</guid><dc:creator><![CDATA[Barky919]]></dc:creator><pubDate>Thu, 22 Aug 2019 11:51:48 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray reboots when USBC power removed on Sun, 18 Aug 2019 08:40:03 GMT]]></title><description><![CDATA[<p dir="auto">Just found this on Twitter:  <a href="https://mobile.twitter.com/lovyan03/status/1162512607279890434" target="_blank" rel="noopener noreferrer nofollow ugc">https://mobile.twitter.com/lovyan03/status/1162512607279890434</a></p>
<p dir="auto">2200μFのコンデンサをM5Stackの3v3とGNDの間に入れてUSB挿抜テスト。ノーマルボトムでは成功、USB抜いてもリセットせずにそのまま動作しました。</p>
<p dir="auto">Using google translate:<br />
Insert a 2200μF capacitor between 3v3 of M5Stack and GND for USB insertion / extraction test. It succeeded in the normal bottom, and it worked as it was without resetting even if USB was removed.</p>
]]></description><link>https://community.m5stack.com/post/5209</link><guid isPermaLink="true">https://community.m5stack.com/post/5209</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 18 Aug 2019 08:40:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray reboots when USBC power removed on Sat, 17 Aug 2019 08:10:45 GMT]]></title><description><![CDATA[<p dir="auto">II have same problem. Date is 2018.3 on board</p>
]]></description><link>https://community.m5stack.com/post/5199</link><guid isPermaLink="true">https://community.m5stack.com/post/5199</guid><dc:creator><![CDATA[progman]]></dc:creator><pubDate>Sat, 17 Aug 2019 08:10:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray reboots when USBC power removed on Sat, 03 Aug 2019 05:18:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barky919" aria-label="Profile: barky919">@<bdi>barky919</bdi></a> Please contact M5Stack support and tell them your issues including this reference date.</p>
]]></description><link>https://community.m5stack.com/post/4991</link><guid isPermaLink="true">https://community.m5stack.com/post/4991</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 03 Aug 2019 05:18:50 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray reboots when USBC power removed on Fri, 02 Aug 2019 20:48:35 GMT]]></title><description><![CDATA[<p dir="auto">Tnx;<br />
It has "2018.3" on the small white square.</p>
]]></description><link>https://community.m5stack.com/post/4985</link><guid isPermaLink="true">https://community.m5stack.com/post/4985</guid><dc:creator><![CDATA[Barky919]]></dc:creator><pubDate>Fri, 02 Aug 2019 20:48:35 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray reboots when USBC power removed on Fri, 02 Aug 2019 12:01:16 GMT]]></title><description><![CDATA[<p dir="auto">On the main pcb is a white square with a date on it. what does you have written there?</p>
]]></description><link>https://community.m5stack.com/post/4973</link><guid isPermaLink="true">https://community.m5stack.com/post/4973</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 02 Aug 2019 12:01:16 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray reboots when USBC power removed on Fri, 02 Aug 2019 11:49:03 GMT]]></title><description><![CDATA[<p dir="auto">I have tried jumping the Reset pin to +3.3V, but it still reboots when I unplug the USB cable:</p>
<li>Internal battery; powered on. Connect the USB cable = no reboot.</li>
<li>Internal battery; powered on. Disconnect the USB cable = immediate reboot.</li>
]]></description><link>https://community.m5stack.com/post/4972</link><guid isPermaLink="true">https://community.m5stack.com/post/4972</guid><dc:creator><![CDATA[Barky919]]></dc:creator><pubDate>Fri, 02 Aug 2019 11:49:03 GMT</pubDate></item></channel></rss>
