<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Easy way to destroy an M5 stack]]></title><description><![CDATA[<p dir="auto">The right button on one of my M5s was shifted so only 1/2 the button was showing.  I couldn't move it into place because some tape or glue was holding it.  I should have contacted M5Stack at this point, but I didn't want to wait for a reply on this forum and I thought it would be easy to take the two screws off the back and re-seat the buttons.</p>
<p dir="auto">I lifted the speaker out, then I thought I could push the board to the side to get it to lift out over the plastic notch.  I ended up ripping the ribbon off the solder pads :(  I had probably weakened the ribbon by lifting the board up several times trying to get the buttons in place without removing the board out completely.</p>
<p dir="auto"><strong>Has anyone seen any instructions on how to remove the main board?</strong>   I totally failed here :(  I'm guessing there's a trick to pull the board over to one side so the board clears the notch, then lift it straight up.  I thought I had it by removing the speaker first, but maybe by that time I had weakened the ribbon too much.</p>
]]></description><link>https://community.m5stack.com/topic/117/easy-way-to-destroy-an-m5-stack</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:40:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/117.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Feb 2018 01:09:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Easy way to destroy an M5 stack on Fri, 02 Mar 2018 21:31:15 GMT]]></title><description><![CDATA[<p dir="auto">Usually shipping to China isn't cost effective for us in Canada.</p>
<p dir="auto">I think you have answered my questions.  There is no video to disassemble it.  If I ever receive another broken unit, I'll contact you to see how you want to handle it.</p>
]]></description><link>https://community.m5stack.com/post/495</link><guid isPermaLink="true">https://community.m5stack.com/post/495</guid><dc:creator><![CDATA[ScottS]]></dc:creator><pubDate>Fri, 02 Mar 2018 21:31:15 GMT</pubDate></item><item><title><![CDATA[Reply to Easy way to destroy an M5 stack on Fri, 02 Mar 2018 02:19:08 GMT]]></title><description><![CDATA[<p dir="auto">We do not recommend that users attempt to disassemble the device themselves, it will break the glass maybe.</p>
]]></description><link>https://community.m5stack.com/post/493</link><guid isPermaLink="true">https://community.m5stack.com/post/493</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 02 Mar 2018 02:19:08 GMT</pubDate></item></channel></rss>
