<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow can&#x27;t  download code in m5stick-c recently.]]></title><description><![CDATA[<p dir="auto">I can only run the code, not download the code. I tried two sticks, both of which are the same，as if they had only appeared in the past few days.Error prompt：Upload code failed,maybe your device is offline check it and retry.</p>
]]></description><link>https://community.m5stack.com/topic/1215/uiflow-can-t-download-code-in-m5stick-c-recently</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 12:22:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1215.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Aug 2019 09:40:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow can&#x27;t  download code in m5stick-c recently. on Wed, 14 Aug 2019 07:38:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/lsy51739488" aria-label="Profile: lsy51739488">@<bdi>lsy51739488</bdi></a> I just tested Stick C on both beta and 1.3.2 Uiflow with no connection issues. I was using firmware 1.3.5 firmware but older firmwares should also work fine. Are you still having issues?</p>
]]></description><link>https://community.m5stack.com/post/5139</link><guid isPermaLink="true">https://community.m5stack.com/post/5139</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 14 Aug 2019 07:38:44 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow can&#x27;t  download code in m5stick-c recently. on Wed, 14 Aug 2019 06:57:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lsy51739488" aria-label="Profile: lsy51739488">@<bdi>lsy51739488</bdi></a>  try USB connection and refirmware with latest UIFlow FW</p>
]]></description><link>https://community.m5stack.com/post/5135</link><guid isPermaLink="true">https://community.m5stack.com/post/5135</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Wed, 14 Aug 2019 06:57:28 GMT</pubDate></item></channel></rss>
