<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Running without battery - power switch]]></title><description><![CDATA[<p dir="auto">Just ordered 2018 model. Excited to find such a well thought out ESP32 design. Whilst I wait and prototype with my other ESP32 boards, I have a few questions I cannot tell from the schematic as the power module datasheet is not in English. I intend to power it from a stable 5V power supply and want it to turn on when it is powered.</p>
<li>Does the power switch need to be pressed to turn on?</li>
<li>Can it be powered through the pin headers or the 5V and GND of the Grove connector instead of USB?</li>
<li>If so, can it also be connected to USB?</li>
<p dir="auto">Are there schematics for the latest 2018 version with the 4MiB PSRAM?</p>
<p dir="auto">Also thinking of using the other Grove pins as GPIO. They don't appear to be shared?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/122/running-without-battery-power-switch</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 15:37:05 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/122.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 03 Mar 2018 23:19:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Running without battery - power switch on Mon, 05 Mar 2018 19:53:12 GMT]]></title><description><![CDATA[<p dir="auto">Is it easy to disable the MPU9250 so that I can use the pins as GPIO? In this case for an ethanol content sensor with pullup to 3.3V. Or would I be better with an M5stack without MPU9250?</p>
<p dir="auto">By adding a CAN transceiver inside, I will have a new twisted pair coming out of the case, but if I power through USB C and use Grove for GPIO I could get rid of all the pin headers and use a slimmer base.</p>
<p dir="auto">For an order in quantity of hundreds, what customisations are feasible? Having a unit with a CAN transceiver, no battery and a slimmer base already would probably cost less to manufacture, but it depends on the quantities to design another model.</p>
]]></description><link>https://community.m5stack.com/post/515</link><guid isPermaLink="true">https://community.m5stack.com/post/515</guid><dc:creator><![CDATA[jcsbanks]]></dc:creator><pubDate>Mon, 05 Mar 2018 19:53:12 GMT</pubDate></item><item><title><![CDATA[Reply to Running without battery - power switch on Mon, 05 Mar 2018 15:54:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcsbanks" aria-label="Profile: jcsbanks">@<bdi>jcsbanks</bdi></a> 在 <a href="/post/500">Running without battery - power switch</a> 中说：</p>
<p dir="auto">MPU9250 uses the same pins as Grove I2C, so I think I will not be using that port unless some other 2018 versions do not have MPU9250.</p>
<p dir="auto">You could use an external I2C GPIO expander like the MCP23017 or SX1509 connected via the Grove connector and still use the MPU9250.</p>
]]></description><link>https://community.m5stack.com/post/512</link><guid isPermaLink="true">https://community.m5stack.com/post/512</guid><dc:creator><![CDATA[pkourany]]></dc:creator><pubDate>Mon, 05 Mar 2018 15:54:02 GMT</pubDate></item><item><title><![CDATA[Reply to Running without battery - power switch on Sun, 04 Mar 2018 21:33:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcsbanks" aria-label="Profile: jcsbanks">@<bdi>jcsbanks</bdi></a> Hi JC,</p>
<p dir="auto">If you plug the M5 into usb when the M5 is off, the M5 will power on without pressing the on button.</p>
<p dir="auto">Powering from the headers is not recommended -  github:  <a href="https://github.com/m5stack/M5Stack/issues/29" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Stack/issues/29</a></p>
<p dir="auto">The schematics listed online are for the recent model you ordered - with 4 Mb PS-RAM and MPU9250.<br />
<a href="http://m5stack.com/download/M5-Core-Schematic(20171206).pdf" target="_blank" rel="noopener noreferrer nofollow ugc">http://m5stack.com/download/M5-Core-Schematic(20171206).pdf</a></p>
]]></description><link>https://community.m5stack.com/post/504</link><guid isPermaLink="true">https://community.m5stack.com/post/504</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sun, 04 Mar 2018 21:33:16 GMT</pubDate></item><item><title><![CDATA[Reply to Running without battery - power switch on Sun, 04 Mar 2018 12:13:58 GMT]]></title><description><![CDATA[<p dir="auto">Translated section of IP5306 datasheet: "IP5306 can recognize long key and short key operation, PIN5 pin is vacant when the key is not needed. ● The button lasts longer than 50ms, but less than 2s, it means the short press, short press will turn on the power indicator and boost output. ● If the duration of the key is longer than 2s, the long press will activate the light and turn it on or off. ● less than 50ms button action will not have any response. ● Pressing the short key twice within 1 second will turn off the boost output, battery level indicator and lighting LED"</p>
<p dir="auto">It sounds like it will power up without pressing the power key, and that may be in the user guide when I zoom into screen shots of it, but I cannot find the pdf to download.</p>
<p dir="auto">If I need to, I could remove pin 8 connection of IP5306 to allow simultaneous USB comms (without power) whilst running another 5V input.</p>
]]></description><link>https://community.m5stack.com/post/500</link><guid isPermaLink="true">https://community.m5stack.com/post/500</guid><dc:creator><![CDATA[jcsbanks]]></dc:creator><pubDate>Sun, 04 Mar 2018 12:13:58 GMT</pubDate></item></channel></rss>
