<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Code download does not properly work for UI flow]]></title><description><![CDATA[<p dir="auto">Hi, I'm using M5FIRE with UIflow.<br />
What I'm doing is sending ENV. sensor data to server.</p>
<p dir="auto">The code I wrote works when I just run the code from RUN button on UI flow web, but does not work when I download the code on M5FIRE from download button.<br />
Is there any possible issue and solution?</p>
]]></description><link>https://community.m5stack.com/topic/1228/code-download-does-not-properly-work-for-ui-flow</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:33:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1228.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Aug 2019 23:53:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Code download does not properly work for UI flow on Fri, 16 Aug 2019 01:37:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heybin" aria-label="Profile: heybin">@<bdi>heybin</bdi></a> It works now!! Thank you so much</p>
]]></description><link>https://community.m5stack.com/post/5182</link><guid isPermaLink="true">https://community.m5stack.com/post/5182</guid><dc:creator><![CDATA[star1120]]></dc:creator><pubDate>Fri, 16 Aug 2019 01:37:16 GMT</pubDate></item><item><title><![CDATA[Reply to Code download does not properly work for UI flow on Fri, 16 Aug 2019 01:10:40 GMT]]></title><description><![CDATA[<p dir="auto">please add this block<br />
<img src="/assets/uploads/files/1565917821747-e67972f2-46a2-4b8b-a29f-b9529dff5036-image-resized.png" alt="0_1565917820787_e67972f2-46a2-4b8b-a29f-b9529dff5036-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/5181</link><guid isPermaLink="true">https://community.m5stack.com/post/5181</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Fri, 16 Aug 2019 01:10:40 GMT</pubDate></item></channel></rss>
