<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fire &amp; Base Node]]></title><description><![CDATA[<p dir="auto">Hi all, hope everyone is well:..</p>
<p dir="auto">My sml project involves playing .mp3's via SD card using Fire/M5 Node. What I did (while waiting for M5 Node) and works well, M5 Fire + M5 Bus module to break out GPIO pins for I2S Bus + attached an external I2S board and ear buds (see images). Using M5 example (PlayMP3FromSDToDac) and some tweaking I have audio streaming from SD card - sound great.</p>
<p dir="auto">Now I have M5 Node and using LED RGB example, Ok that works, but not having much luck playing .mp3's using Fire &amp; Node though. I know that the GPIO pins need to be remapped to suit I2S configuration on M5 Node (according to NODE docs), used/remapped GPIO 13,5 &amp; 2 in PlayMP3FromSDToDAC example. So wondering (and thks in advance) if anyone may have some thought's.</p>
<p dir="auto">Additional - does anyone know if any audio example's exist for the M5 Node?. Seems strange I.e create a nice bit of audio hardware + docs with no example! What am I missing here?</p>
<p dir="auto">Cheers<br />
M</p>
<p dir="auto">Objective<br />
<img src="/assets/uploads/files/1565998939209-dac03.jpg" alt="0_1565998931086_Dac03.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Modified code below works with external I2S (UDA1334), but not with M5Node<br />
<img src="/assets/uploads/files/1565938468099-dac00-resized.jpg" alt="0_1565938450557_Dac00.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Node PinOuts - Using pins I2S, LRC/BCLK/DACDAT/ 5V &amp; GND.<br />
<img src="/assets/uploads/files/1565938499243-dac01.jpg" alt="0_1565938485679_Dac01.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Works, UDA1334 connected to Fires I2S Bus via breakout (sounds awesome)<br />
<img src="/assets/uploads/files/1565938521868-dac02.jpg" alt="0_1565938507083_Dac02.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/1229/fire-base-node</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 17:15:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1229.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Aug 2019 07:02:30 GMT</pubDate><ttl>60</ttl></channel></rss>
