<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What grove modules are compatible with the m5stickc?]]></title><description><![CDATA[<p dir="auto">Hi, I'm new to the microcontrollers and boards. I would like to buy the m5stickc and some sensors but I don't know what grove modules are compatible with the m5stickc. If I understand correctly, the grove connector in the m5stick is only compatible with the i2c modules but I was wondering if would be possible to connect also the GPIO modules using the 8 pins extension connector and a breadboard. Is that possible?.</p>
]]></description><link>https://community.m5stack.com/topic/1240/what-grove-modules-are-compatible-with-the-m5stickc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:31:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1240.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Aug 2019 16:26:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What grove modules are compatible with the m5stickc? on Fri, 04 Oct 2019 23:14:50 GMT]]></title><description><![CDATA[<p dir="auto">Just for future references. The dual button module works fine using the 8 pines connector with a breadboard or directly with the grove connector. You just need to use the correct numbers in Arduino (I didn't test micropython).</p>
<p dir="auto">You only can use G36 as input, everything else can work as input/output.</p>
]]></description><link>https://community.m5stack.com/post/5826</link><guid isPermaLink="true">https://community.m5stack.com/post/5826</guid><dc:creator><![CDATA[quiaxek]]></dc:creator><pubDate>Fri, 04 Oct 2019 23:14:50 GMT</pubDate></item><item><title><![CDATA[Reply to What grove modules are compatible with the m5stickc? on Wed, 21 Aug 2019 01:23:22 GMT]]></title><description><![CDATA[<p dir="auto">I've used the seeedstudio sevseg display with the M5Stack but not the stick but I shouldn't see an issue there. I'm currently writing a guide on <a href="http://hackster.io" target="_blank" rel="noopener noreferrer nofollow ugc">hackster.io</a> for it and experimenting with creating custom blocks in Uiflow for it also</p>
]]></description><link>https://community.m5stack.com/post/5261</link><guid isPermaLink="true">https://community.m5stack.com/post/5261</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 21 Aug 2019 01:23:22 GMT</pubDate></item><item><title><![CDATA[Reply to What grove modules are compatible with the m5stickc? on Tue, 20 Aug 2019 22:44:19 GMT]]></title><description><![CDATA[<p dir="auto">I have posted my notes on using the stick with some Grove modules (over the grove connector) here: <a href="http://tinkerfarm.net/projects/the-m5stickc/m5stickc-hardware-accessories/" target="_blank" rel="noopener noreferrer nofollow ugc">http://tinkerfarm.net/projects/the-m5stickc/m5stickc-hardware-accessories/</a></p>
]]></description><link>https://community.m5stack.com/post/5260</link><guid isPermaLink="true">https://community.m5stack.com/post/5260</guid><dc:creator><![CDATA[wikistik]]></dc:creator><pubDate>Tue, 20 Aug 2019 22:44:19 GMT</pubDate></item><item><title><![CDATA[Reply to What grove modules are compatible with the m5stickc? on Tue, 20 Aug 2019 15:53:03 GMT]]></title><description><![CDATA[<p dir="auto">Thank you both for the help!. I bought the stickc yesterday and a few gpio grove modules. I was looking how the gpio ports work and the 8 pines port should be enough to connect a gpio module.</p>
]]></description><link>https://community.m5stack.com/post/5259</link><guid isPermaLink="true">https://community.m5stack.com/post/5259</guid><dc:creator><![CDATA[quiaxek]]></dc:creator><pubDate>Tue, 20 Aug 2019 15:53:03 GMT</pubDate></item><item><title><![CDATA[Reply to What grove modules are compatible with the m5stickc? on Tue, 20 Aug 2019 14:23:52 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">with the PbHub the PortB Units should also be able to be connected to the StickC. But I didn't try that.<br />
PbHub: <a href="https://docs.m5stack.com/#/en/unit/pbhub" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/pbhub</a></p>
<p dir="auto">greetings</p>
]]></description><link>https://community.m5stack.com/post/5258</link><guid isPermaLink="true">https://community.m5stack.com/post/5258</guid><dc:creator><![CDATA[Gaius]]></dc:creator><pubDate>Tue, 20 Aug 2019 14:23:52 GMT</pubDate></item><item><title><![CDATA[Reply to What grove modules are compatible with the m5stickc? on Mon, 19 Aug 2019 16:57:17 GMT]]></title><description><![CDATA[<p dir="auto">The Stick C has its own range of H.A.Ts containing sensors and these should work as they are i2c.<br />
ADC,<br />
CardKB,<br />
Colour Sensor<br />
DAC,<br />
Environment,<br />
EXT I/O,<br />
Heart,<br />
I2C Expander,<br />
Joystick,<br />
Makey Makey,<br />
NeoFlash*,<br />
NCIR,<br />
RFID<br />
Thermal,<br />
TOF,<br />
Trace *(1)</p>
]]></description><link>https://community.m5stack.com/post/5241</link><guid isPermaLink="true">https://community.m5stack.com/post/5241</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 19 Aug 2019 16:57:17 GMT</pubDate></item></channel></rss>
