<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Env vs Hat Env]]></title><description><![CDATA[<p dir="auto">Hey all,</p>
<p dir="auto">finally i have some time to play with Env Hat, at first time there was some strange readings +-5% diff then normal env.<br />
Now there was time to check this out and here it is:<br />
<img src="https://i.ibb.co/6BP9fYs/Adobe-Post-20190814-210415.png" alt="text alternatywny" class=" img-fluid img-markdown" /><br />
and HW inside:<br />
<img src="https://i.ibb.co/dMCyy90/Adobe-Post-20190814-210401.png" alt="text alternatywny" class=" img-fluid img-markdown" /></p>
<p dir="auto">HW info:<br />
M5StickC ENV Hat (DHT12, BMP280, BMM150)<br />
ENV Unit with Temperature Humidity Pressure Sensor (DHT12+BMP280)</p>
<p dir="auto">Inside ENV Hat we have DHT12 without blue case du the size, but why there is so big difference between normal Env ?</p>
<p dir="auto">Any clue ?</p>
<p dir="auto">Just BTW i have 3 Env Hat and all works in same way.</p>
<p dir="auto">Regards</p>
]]></description><link>https://community.m5stack.com/topic/1241/env-vs-hat-env</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:06:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1241.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Aug 2019 17:02:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Env vs Hat Env on Thu, 05 Sep 2019 20:22:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grlind" aria-label="Profile: grlind">@<bdi>grlind</bdi></a> I was able to get to work in Ardunio I just combine the DHT into the main sketch all things good though the pressure reading are off... I owuld like to see the uflow - I have not done anything in uflow want to try it.. Is your code posted somewhere?</p>
]]></description><link>https://community.m5stack.com/post/5489</link><guid isPermaLink="true">https://community.m5stack.com/post/5489</guid><dc:creator><![CDATA[grlind]]></dc:creator><pubDate>Thu, 05 Sep 2019 20:22:38 GMT</pubDate></item><item><title><![CDATA[Reply to Env vs Hat Env on Fri, 30 Aug 2019 08:39:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dda" aria-label="Profile: dda">@<bdi>dda</bdi></a> said in <a href="/post/5383">Env vs Hat Env</a>:</p>
<p dir="auto">@mati I have mentioned this to Jimmi, and his answer basically was, well don't use wifi and OLED. Not exactly a practical answer. I'd rather have a long hat, isolating the DHT and BMP from the heat.</p>
<p dir="auto">rlly ?! hmm what's the point of making HAT with req extra cable to unHAT it :D<br />
ok let's end this topic as a lesson. thx <a class="plugin-mentions-user plugin-mentions-a" href="/user/dda" aria-label="Profile: dda">@<bdi>dda</bdi></a> for info.</p>
]]></description><link>https://community.m5stack.com/post/5384</link><guid isPermaLink="true">https://community.m5stack.com/post/5384</guid><dc:creator><![CDATA[OyczE]]></dc:creator><pubDate>Fri, 30 Aug 2019 08:39:34 GMT</pubDate></item><item><title><![CDATA[Reply to Env vs Hat Env on Fri, 30 Aug 2019 07:30:42 GMT]]></title><description><![CDATA[<p dir="auto">@mati I have mentioned this to Jimmi, and his answer basically was, well don't use wifi and OLED. Not exactly a practical answer. I'd rather have a long hat, isolating the DHT and BMP from the heat.</p>
]]></description><link>https://community.m5stack.com/post/5383</link><guid isPermaLink="true">https://community.m5stack.com/post/5383</guid><dc:creator><![CDATA[dda]]></dc:creator><pubDate>Fri, 30 Aug 2019 07:30:42 GMT</pubDate></item><item><title><![CDATA[Reply to Env vs Hat Env on Thu, 29 Aug 2019 05:55:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grlind" aria-label="Profile: grlind">@<bdi>grlind</bdi></a> well its simple UIFlow drag and drop showcase.<br />
I will try to do same in arduino today.</p>
]]></description><link>https://community.m5stack.com/post/5361</link><guid isPermaLink="true">https://community.m5stack.com/post/5361</guid><dc:creator><![CDATA[OyczE]]></dc:creator><pubDate>Thu, 29 Aug 2019 05:55:01 GMT</pubDate></item><item><title><![CDATA[Reply to Env vs Hat Env on Wed, 28 Aug 2019 15:29:32 GMT]]></title><description><![CDATA[<p dir="auto">@mati</p>
<p dir="auto">Can you tell me how to compile the code I am confused on how to bring the code into the Arduino IDE.</p>
<p dir="auto">I created a main sketch and then copied the code into Mstickc_ENVHat, I also created 4 tabs..  DHT12.cpp, DHT12.h, and bmm150.cpp, and bmm150.h, and bmm150_defs.h...</p>
<p dir="auto">I get errors</p>
<p dir="auto">C:\Users\AppData\Local\Temp\arduino_build_90317\sketch\MstickC_ENVhat.ino.cpp.o:(.literal._Z4loopv+0x34): undefined reference to `DHT12::readTemperature(unsigned char)'</p>
<p dir="auto">C:\Users\AppData\Local\Temp\arduino_build_90317\sketch\MstickC_ENVhat.ino.cpp.o:(.literal._Z4loopv+0x38): undefined reference to `DHT12::readHumidity()'</p>
]]></description><link>https://community.m5stack.com/post/5351</link><guid isPermaLink="true">https://community.m5stack.com/post/5351</guid><dc:creator><![CDATA[grlind]]></dc:creator><pubDate>Wed, 28 Aug 2019 15:29:32 GMT</pubDate></item><item><title><![CDATA[Reply to Env vs Hat Env on Wed, 28 Aug 2019 09:12:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dda" aria-label="Profile: dda">@<bdi>dda</bdi></a> said in <a href="/post/5244">Env vs Hat Env</a>:</p>
<p dir="auto">If you have the OLED and WiFi on, the heat they produce will skew the results. I connect the ENV hat to my Stick C with wires, and I get different, lower-temp results.</p>
<p dir="auto">So after test with extra cables all is ok when hat is moved out from stick.</p>
<p dir="auto">But this is a main clue of hat to stick it in to StickC without extra lobg cable.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> please comment this, for me this looks like design issue.</p>
]]></description><link>https://community.m5stack.com/post/5342</link><guid isPermaLink="true">https://community.m5stack.com/post/5342</guid><dc:creator><![CDATA[OyczE]]></dc:creator><pubDate>Wed, 28 Aug 2019 09:12:35 GMT</pubDate></item><item><title><![CDATA[Reply to Env vs Hat Env on Tue, 20 Aug 2019 05:05:01 GMT]]></title><description><![CDATA[<p dir="auto">Ok let me try it. So the whole clue of env hat should come with some kind of shield to eliminate heat from stick.</p>
]]></description><link>https://community.m5stack.com/post/5253</link><guid isPermaLink="true">https://community.m5stack.com/post/5253</guid><dc:creator><![CDATA[OyczE]]></dc:creator><pubDate>Tue, 20 Aug 2019 05:05:01 GMT</pubDate></item><item><title><![CDATA[Reply to Env vs Hat Env on Mon, 19 Aug 2019 18:28:51 GMT]]></title><description><![CDATA[<p dir="auto">If you have the OLED and WiFi on, the heat they produce will skew the results. I connect the ENV hat to my Stick C with wires, and I get different, lower-temp results.</p>
]]></description><link>https://community.m5stack.com/post/5244</link><guid isPermaLink="true">https://community.m5stack.com/post/5244</guid><dc:creator><![CDATA[dda]]></dc:creator><pubDate>Mon, 19 Aug 2019 18:28:51 GMT</pubDate></item></channel></rss>
