<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Use Pa.hub with Uiflow]]></title><description><![CDATA[<p dir="auto">Hello everyone!<br />
I bought a Pa.hub. I would like to use it with Uiflow.<br />
I tested with Extend i / o on channel 0 of Pa.hub but did not work. The Extend i / o is not visible by the M5Stick-c.<br />
Someone will have an example code in Uiflow?</p>
<p dir="auto">Thank you</p>
]]></description><link>https://community.m5stack.com/topic/1242/use-pa-hub-with-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 01:25:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1242.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Aug 2019 18:22:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Use Pa.hub with Uiflow on Mon, 19 Aug 2019 18:42:32 GMT]]></title><description><![CDATA[<p dir="auto">I do have demo micropython code for that found here<br />
<a href="http://community.m5stack.com/topic/1104/pahub-access-cracked" target="_blank" rel="noopener noreferrer nofollow ugc">PaHub Code Demo</a><br />
It was built using UIFlows blocks but alas I didn't save the file :(</p>
<p dir="auto">BTW you have to initialise the i2c port before accessing it.<br />
I don't think the Stick C can power it which I think is the reason that it is disabled in UIFLow.</p>
]]></description><link>https://community.m5stack.com/post/5245</link><guid isPermaLink="true">https://community.m5stack.com/post/5245</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 19 Aug 2019 18:42:32 GMT</pubDate></item></channel></rss>
