<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issue in sending roll angle to Azure IoT Hub]]></title><description><![CDATA[<p dir="auto">When I am trying to capture roll angle using M5stack Gray it is working fine and separate code for sending data to Azure IoT Hub is also working fine. But when I try to club the two modules the roll angle return by module get highly unstable and it throws random absurd values.<img src="/assets/uploads/files/1566540208690-screenshot-32-resized.png" alt="0_1566540204514_Screenshot (32).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/1247/issue-in-sending-roll-angle-to-azure-iot-hub</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 17:15:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1247.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Aug 2019 06:03:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issue in sending roll angle to Azure IoT Hub on Mon, 14 Oct 2019 11:26:40 GMT]]></title><description><![CDATA[<p dir="auto">Hi, did you solve this? Sounds like a scope, or casting issue.</p>
<p dir="auto">I'm having a different problem with the IMU and I can see you have a IMU class with Gyro, Accel and Mag data incorporated. Is it for the MPU6886 + BMM150 sensors.</p>
<p dir="auto">Would you be happy to let me have a look at :</p>
<li>IMU class .h &amp; .cpp files.</li>
<li>MahonyAHRS.h &amp; .cpp files.</li>
<p dir="auto">I'm fighting with the MahonyAHRSUpdate I'm using. The calculations are diverging to NaN after just 2-3 calls and I'd like to compare your code to mine.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/post/5961</link><guid isPermaLink="true">https://community.m5stack.com/post/5961</guid><dc:creator><![CDATA[CouldDobetter]]></dc:creator><pubDate>Mon, 14 Oct 2019 11:26:40 GMT</pubDate></item></channel></rss>
