<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Extrusion mould issue causes crack]]></title><description><![CDATA[<p dir="auto">I had to perform an emergency repair on the housing of a black M5Stack core. The housing started to crack spontaneously on one of its edges, despite hardly using it.<br />
<img src="https://i.imgur.com/W5cnNPP.jpg" alt="crack" class=" img-fluid img-markdown" /><br />
I am suspecting a extrusions mould issue causing to little material to flow to that edge. Such an issue can be corrected on the extrusion mould by adding an extra channel.</p>
]]></description><link>https://community.m5stack.com/topic/127/extrusion-mould-issue-causes-crack</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 20:14:05 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/127.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Mar 2018 21:41:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Extrusion mould issue causes crack on Sun, 11 Mar 2018 21:55:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> No, not at all! It was just sitting on my desk and over the course of two days a crack appeared and gradually grew over the whole width. The other three edges show no problem. This is why I suspect a problem with the extrusion mould.</p>
]]></description><link>https://community.m5stack.com/post/555</link><guid isPermaLink="true">https://community.m5stack.com/post/555</guid><dc:creator><![CDATA[on4aa]]></dc:creator><pubDate>Sun, 11 Mar 2018 21:55:00 GMT</pubDate></item><item><title><![CDATA[Reply to Extrusion mould issue causes crack on Wed, 07 Mar 2018 01:55:11 GMT]]></title><description><![CDATA[<p dir="auto">Do you use it violently?</p>
]]></description><link>https://community.m5stack.com/post/529</link><guid isPermaLink="true">https://community.m5stack.com/post/529</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 07 Mar 2018 01:55:11 GMT</pubDate></item></channel></rss>
