<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hissing Noise from Loudspeaker]]></title><description><![CDATA[<p dir="auto">When I start/reset my M5Stack Fire I get an audible hissing noise.  This is not the case with my M5Stack basic unit.</p>
<p dir="auto">It's loud enough to be annoying. Is this a fault, or a feature?</p>
]]></description><link>https://community.m5stack.com/topic/1299/hissing-noise-from-loudspeaker</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 17:44:50 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1299.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Sep 2019 21:52:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hissing Noise from Loudspeaker on Mon, 09 Sep 2019 05:27:17 GMT]]></title><description><![CDATA[<p dir="auto">Due to hardware flaws, sometimes when interfacing with some of the units there is an audible hiss. Unfortunately since it is a hardware flaw the only solution is to use code to reduce the volume of the hiss.</p>
<p dir="auto">in Arduino it should be something like<br />
dacWrite(25,0)</p>
<p dir="auto">Python<br />
dac0 = machine.DAC(25)<br />
dac0.write(0)</p>
]]></description><link>https://community.m5stack.com/post/5534</link><guid isPermaLink="true">https://community.m5stack.com/post/5534</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Mon, 09 Sep 2019 05:27:17 GMT</pubDate></item><item><title><![CDATA[Reply to Hissing Noise from Loudspeaker on Sat, 07 Sep 2019 18:01:02 GMT]]></title><description><![CDATA[<p dir="auto">Try to remove battery bottom and turn it on with usb power supply only (:</p>
]]></description><link>https://community.m5stack.com/post/5519</link><guid isPermaLink="true">https://community.m5stack.com/post/5519</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Sat, 07 Sep 2019 18:01:02 GMT</pubDate></item><item><title><![CDATA[Reply to Hissing Noise from Loudspeaker on Fri, 06 Sep 2019 22:01:02 GMT]]></title><description><![CDATA[<p dir="auto">I purchased this only a few days ago here in germany from your Partner firm Conrad, (under their own Maker Factory brand). The serial number sticker has faded badly in the 4 days since I bought it (bizzare!), but the number 0441 is still readable, if this is of any help in tracing the fault.</p>
]]></description><link>https://community.m5stack.com/post/5505</link><guid isPermaLink="true">https://community.m5stack.com/post/5505</guid><dc:creator><![CDATA[scotus]]></dc:creator><pubDate>Fri, 06 Sep 2019 22:01:02 GMT</pubDate></item></channel></rss>
