<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lesson 7. MPU9250. Game &quot;SPACE DEFENSE&quot; (beta)]]></title><description><![CDATA[<h2>The purpose of this lesson</h2>
<p dir="auto">Hi! Today we will learn how to work with the built-in sensor MPU9250 in silver model M5STACK.<br />
The MPU9250 sensor includes a gyroscope, accelerometer and compass. In this lesson, we'll write a game "SPACE DEFENSE" (Fig. 1) Controlling the ship will be possible only by means of an inclination device. On the x-axis - the movement of the ship, and on the Y - axis-the opening of fire. Gyroscope and compass study by yourself.</p>
<p dir="auto"><img src="https://pp.userapi.com/c841321/v841321763/75374/CH5UVNz8XFQ.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 1. The start screen of the game</p>
<h2>Brief theory</h2>
<p dir="auto"><img src="https://pp.userapi.com/c834104/v834104988/dcd9f/5rBFXbIUwKU.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 2. The device has a mechanical accelerometer</p>
<p dir="auto">What is an accelerometer? Accelerometer – a device (Fig. 2), measuring the projection of the apparent acceleration (the difference between the true acceleration of the object and the gravitational acceleration). As a rule, the accelerometer is a sensitive mass fixed in an elastic suspension. Deviation of the mass from its initial position in the presence of apparent acceleration carries information about the magnitude of this acceleration.</p>
<p dir="auto">More information on the Wiki: <a href="https://en.wikipedia.org/wiki/Accelerometer" title="https://en.wikipedia.org/wiki/Accelerometer" target="_blank" rel="noopener noreferrer nofollow ugc">https://en.wikipedia.org/wiki/Accelerometer</a></p>
<p dir="auto"><strong>List of components for the lesson</strong></p>
<li>M5stack silver model with built-in MPU9250.</li>
<h2>Begin!</h2>
<h3>Step 1. Draw pictures</h3>
<p dir="auto">Draw a spaceship, a ship explosion and the logo of the game. Use any graphics editor convenient for you. We will use as usual the Paint (Fig. 3 – 3.2).</p>
<p dir="auto"><img src="https://pp.userapi.com/c841321/v841321072/75667/yVYe_4gJPW0.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 3. Draw a space ship</p>
<p dir="auto"><img src="https://pp.userapi.com/c841321/v841321072/75654/mDfqEgQ8uvQ.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 3.1. Draw the logo of the game</p>
<p dir="auto"><img src="https://pp.userapi.com/c841321/v841321072/7565e/gTG6W_rATAA.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 3.2. Collection of drawings for the project</p>
<p dir="auto">In the future, we will connect the images to our new project:</p>
<pre><code>extern unsigned char craft[];
extern unsigned char craft_logo[];
extern unsigned char explode[];
extern unsigned char logo[];
<h3>Step 2. Bullets and space debris</h3>
<p dir="auto">Consider the example of bullets. Let's make a bulletsObject structure that includes the coordinates of the size and state of the bullet (if the bullet is in flight, then busy = true).</p>
<pre><code>struct bulletsObject
	int x;
	int y;
	int width = 3;
	int height = 6;
	bool busy;
<p dir="auto">Now let's do buffer, containing information about three bullets:</p>
<pre><code>const int bullets_max = 3;
bulletsObject bulletsObjectArray[bullets_max];
<p dir="auto">Space debris (if hidden = true, the object is neutralized):</p>
<pre><code>struct spaceDebrisObject
  int x;
  int y;
  int width = 15;
  int height = 15;
  bool hidden;
<p dir="auto">Let's make a buffer containing information about space debris:</p>
<pre><code>const int spaceDebris_max = 100;
spaceDebrisObject spaceDebrisArray[spaceDebris_max];
<h3>Step 3. Let's move things that we have a lot</h3>
<p dir="auto">Multitasking? No – everything is easier. Do you remember - in one of the articles on the Arduino website it was told how to implement led flashing without delay function, which causes the microcontroller to stand idle? If you don't remember, then let's go to read <a href="https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay" title="https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay</a>.<br />
We will do the same (Fig. 5). When the time comes, we will do the necessary actions and update the value of the previous millis time.</p>
<p dir="auto"><img src="https://pp.userapi.com/c830209/v830209723/9fcd0/uGuUidxS0eI.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.</p>
<p dir="auto">Fire function is called from an infinite loop gameLoop() and takes as argument the integer value of the vector of the tilt axis Y. If the value of the vector is less than -250, then you will be fired. Let's talk about how to get values of slope vectors in the next step.<br />
The movement takes place on The screen along the y axis of the entire array with graphical objects (Fig. 5.1).</p>
<p dir="auto"><img src="https://pp.userapi.com/c834103/v834103812/dfee3/zmhyl356kS8.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.1. The principle of motion of graphic objects</p>
<pre><code>void gameLoop() {
  while (true)
    if (!moveCraft(getAccel('X'))) break;
    if (!moveSpaceDebris()) break;
    fire(getAccel('Y'));
    if (health &lt; 0) break;
  craftExplode();
void fire(int vector) {
  if (vector &lt; -250)
    if (!openFire)
      for (int i = 0; i &lt; bullets_max; i++)
        if (!bulletsObjectArray[i].busy)
          openFire = true;
          bulletsObjectArray[i].x = ((craft_x + (craft_width / 2)) - 1);
          bulletsObjectArray[i].y = craft_y;
          bulletsObjectArray[i].busy = true;
          break;
  else
    openFire = false;
  unsigned long millis_ = millis();
  if (((millis_ - moveBullets_pre_millis) &gt;= moveBullets_time))
    moveBullets_pre_millis = millis_;
      M5.Lcd.fillRect(bulletsObjectArray[i].x, bulletsObjectArray[i].y, bulletsObjectArray[i].width, bulletsObjectArray[i].height, 0x0000);
      if (bulletsObjectArray[i].busy)
        bulletsObjectArray[i].y--;
        M5.Lcd.fillRect(bulletsObjectArray[i].x, bulletsObjectArray[i].y, bulletsObjectArray[i].width, bulletsObjectArray[i].height, 0xff80);
        if (bulletsObjectArray[i].y &lt;= statusBar_height)
          bulletsObjectArray[i].busy = false;
        for (int j = 0; j &lt; spaceDebris_max; j++)
          if (((((spaceDebrisArray[j].x + spaceDebrisArray[j].width) &gt;= bulletsObjectArray[i].x) &amp;&amp; (spaceDebrisArray[j].x &lt;= (bulletsObjectArray[i].x + bulletsObjectArray[i].width))) &amp;&amp; ((spaceDebrisArray[j].y + spaceDebrisArray[j].height) &gt;= (bulletsObjectArray[i].y + (bulletsObjectArray[i].height / 2))) &amp;&amp; (spaceDebrisArray[j].y &lt;= (bulletsObjectArray[i].y + bulletsObjectArray[i].height)) &amp;&amp; (!spaceDebrisArray[j].hidden)))
            spaceDebrisArray[j].hidden = true;
            M5.Lcd.fillRect(spaceDebrisArray[j].x, spaceDebrisArray[j].y, spaceDebrisArray[j].width, spaceDebrisArray[j].height, 0x0000);
            score++;
            drawHealthAndScore();
<p dir="auto">If the bullet comes into contact with space debris, the game score increases by one, the state of the bullet takes the value busy = false, space debris becomes hidden hidden = true.</p>
<h3>Step 4. Receiving data from the accelerometer</h3>
<p dir="auto">As was mentioned earlier, the accelerometer returns the values of the angles of deviation from the axes of the "tilt vectors" (Fig. 6).</p>
<p dir="auto"><img src="https://pp.userapi.com/c840232/v840232877/86502/F3a5fzIIDJU.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 6. The vectors of tilt of the accelerometer</p>
<p dir="auto">First of all, you need to connect the library to work with MPU9250:</p>
<pre><code>#include "utility/MPU9250.h"
<p dir="auto">Declare an instance of the class:</p>
<pre><code>MPU9250 IMU;
<p dir="auto">Initialize and calibrate the sensor. Remember that MPU9250 is connected to ESP32 via I2C interface:</p>
<pre><code>void setup(){
	M5.begin();
	Wire.begin();
  	IMU.initMPU9250();
  	IMU.calibrateMPU9250(IMU.gyroBias, IMU.accelBias);
	// any actions
<p dir="auto">Let's write a function that takes as an argument a symbol corresponding to one of the axes 'X', 'Y' or 'Z'. Function returns a vector of the tilt axis. If no data is received, the function returns 0:</p>
<pre><code>int getAccel(char axis) {
  if (IMU.readByte(MPU9250_ADDRESS, INT_STATUS) &amp; 0x01)
    IMU.readAccelData(IMU.accelCount);
    IMU.getAres();
    switch(axis)
      case 'X':
        IMU.ax = (float)IMU.accelCount[0] * IMU.aRes * 1000;
        return IMU.ax;
      case 'Y':
        IMU.ax = (float)IMU.accelCount[1] * IMU.aRes * 1000;
        return IMU.ax;
      case 'Z':
        IMU.az = (float)IMU.accelCount[2] * IMU.aRes * 1000;
        return IMU.az;
  return 0;
<h3>Step 5. Moving the spaceship</h3>
<p dir="auto">The function is overly simple, the principle of operation we considered in the previous step:</p>
<pre><code>bool moveCraft(int vector) {
  if (((millis_ - moveCraft_pre_millis) &gt;= moveCraft_time))
    moveCraft_pre_millis = millis_;
    int craft_x_pre = craft_x;
    if (abs(vector) &gt; 70)
      if (vector &gt; 0)
        craft_x -= craft_step;
      else if (vector &lt; 0)
        craft_x += craft_step;
      M5.Lcd.fillRect(craft_x_pre, craft_y, craft_width, craft_height, 0x0000);
    if ((craft_x &lt; (screen_width - craft_width - craft_step)) &amp;&amp; (craft_x &gt; craft_step))
      M5.Lcd.drawBitmap(craft_x, craft_y, craft_width, craft_height, (uint16_t *)craft);
    else
      return false;
  return true;
<h3>Step 6. The game is over</h3>
<pre><code>void gameOver() {
  M5.Lcd.fillScreen(0x0000);
  M5.Lcd.setTextSize(2);
  M5.Lcd.setTextColor(0x7bef);
  M5.Lcd.setCursor(35, 80);
  M5.Lcd.print("GAME OVER");
  M5.Lcd.setCursor(35, 110);
  M5.Lcd.print("score: ");
  M5.Lcd.print(score);
  M5.Lcd.setCursor(35, 140);
  M5.Lcd.print("please, press any key");
  gameReset();
  while(true)
    M5.update();
    if (M5.BtnA.wasPressed() || M5.BtnB.wasPressed() || M5.BtnC.wasPressed()) break;
<h3>Step 7. Launch!</h3>
<p dir="auto">In General, it was a very interesting project dedicated to work with the accelerometer on Board MPU9250. Let's start and see how it works (Fig. 7, 7.1.):</p>
<p dir="auto"><img src="https://pp.userapi.com/c834103/v834103208/dc770/cTQh-VxOKFY.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 7. Gameplay</p>
<p dir="auto"><img src="https://pp.userapi.com/c834103/v834103208/dc784/TpC1BlB82NA.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure. 7.1. The game is over</p>
<h3>Download</h3>
<li>
<p dir="auto">Video demonstration of the work (YouTube): <a href="https://youtu.be/9gyiFfciUU4" title="https://youtu.be/9gyiFfciUU4" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/9gyiFfciUU4</a></p>
</li>
<li>
<p dir="auto">Source code (GitHub):  <a href="https://github.com/dsiberia9s/SpaceDefense-m5stack" title="https://github.com/dsiberia9s/SpaceDefense-m5stack" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/dsiberia9s/SpaceDefense-m5stack</a></p>
</li>
<li>
<p dir="auto">Image converters (Yandex Disk):<a href="https://yadi.sk/d/m2zvebPf3T5Zrc" title="https://yadi.sk/d/m2zvebPf3T5Zrc" target="_blank" rel="noopener noreferrer nofollow ugc">https://yadi.sk/d/m2zvebPf3T5Zrc</a></p>
</li>
<li>
<p dir="auto">Images (Yandex Disk): <a href="https://yadi.sk/d/JMMyPHOq3T5Zmf" title="https://yadi.sk/d/JMMyPHOq3T5Zmf" target="_blank" rel="noopener noreferrer nofollow ugc">https://yadi.sk/d/JMMyPHOq3T5Zmf</a></p>
</li>
]]></description><link>https://community.m5stack.com/topic/130/lesson-7-mpu9250-game-space-defense-beta</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 20:13:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/130.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Mar 2018 13:27:14 GMT</pubDate><ttl>60</ttl></channel></rss>
