<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[StickC - Serial Problems]]></title><description><![CDATA[<p dir="auto">Ordered StickC from Amazon.  Label on plastic box: @1043907@07-02.</p>
<p dir="auto">Can't get a COM port on Windows 10.  Most of the time 'Unknown USB Device (Device Descriptor Request Failed)', so I can't even install the correct driver.  Works sometimes on OSX.  Used M5Burner to flash 1.4.0-b, then 1.3.2 after 10 tries.  I want to reflash with 1.3.2.  But now all I get is: 'Could not configure port (6, Device Not Configured).</p>
<p dir="auto">Any ideas?</p>
Chris</p>
]]></description><link>https://community.m5stack.com/topic/1323/stickc-serial-problems</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 21:12:11 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1323.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 15 Sep 2019 00:13:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to StickC - Serial Problems on Sun, 22 Sep 2019 02:58:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Tried a different cable, so I'm assuming stick.  Why not edit <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a>.  It's micropython, as long as I call the M5 libs during the process, everything should work as intended.</p>
]]></description><link>https://community.m5stack.com/post/5679</link><guid isPermaLink="true">https://community.m5stack.com/post/5679</guid><dc:creator><![CDATA[cmisztur]]></dc:creator><pubDate>Sun, 22 Sep 2019 02:58:23 GMT</pubDate></item><item><title><![CDATA[Reply to StickC - Serial Problems on Wed, 18 Sep 2019 04:41:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cmisztur" aria-label="Profile: cmisztur">@<bdi>cmisztur</bdi></a> said in <a href="/post/5621">StickC - Serial Problems</a>:</p>
<p dir="auto">Got another one from Amazon and this one works just fine.  Chalking it up to busted during shipping :).</p>
<p dir="auto">Stick or lead?<br />
also don't edit <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a></p>
]]></description><link>https://community.m5stack.com/post/5624</link><guid isPermaLink="true">https://community.m5stack.com/post/5624</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 18 Sep 2019 04:41:35 GMT</pubDate></item><item><title><![CDATA[Reply to StickC - Serial Problems on Wed, 18 Sep 2019 00:12:24 GMT]]></title><description><![CDATA[<p dir="auto">Got another one from Amazon and this one works just fine.  Chalking it up to busted during shipping :).</p>
]]></description><link>https://community.m5stack.com/post/5621</link><guid isPermaLink="true">https://community.m5stack.com/post/5621</guid><dc:creator><![CDATA[cmisztur]]></dc:creator><pubDate>Wed, 18 Sep 2019 00:12:24 GMT</pubDate></item><item><title><![CDATA[Reply to StickC - Serial Problems on Sun, 15 Sep 2019 17:41:39 GMT]]></title><description><![CDATA[<p dir="auto">Same story this morning.  Last night flashed the Arduino FactoryTest.  This morning trying to get this thing connected on Windows, which is where I flashed it last night.</p>
<p dir="auto"><img src="/assets/uploads/files/1568568986651-a0b9581c-aa3b-411a-8ab4-697877719d87-image.png" alt="0_1568568983861_a0b9581c-aa3b-411a-8ab4-697877719d87-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1568569297629-5c93d4f6-596d-48b5-ad38-984b6fee0cbb-image.png" alt="0_1568569295229_5c93d4f6-596d-48b5-ad38-984b6fee0cbb-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/5596</link><guid isPermaLink="true">https://community.m5stack.com/post/5596</guid><dc:creator><![CDATA[cmisztur]]></dc:creator><pubDate>Sun, 15 Sep 2019 17:41:39 GMT</pubDate></item><item><title><![CDATA[Reply to StickC - Serial Problems on Sun, 15 Sep 2019 15:09:56 GMT]]></title><description><![CDATA[<p dir="auto">Used the cable that came with it, marked M5.  I don't know that is the issue.  Before I really had a hard time I modified <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a> and noticed I was getting a GURU error, so ESP was stuck in a never ending reboot.</p>
]]></description><link>https://community.m5stack.com/post/5595</link><guid isPermaLink="true">https://community.m5stack.com/post/5595</guid><dc:creator><![CDATA[cmisztur]]></dc:creator><pubDate>Sun, 15 Sep 2019 15:09:56 GMT</pubDate></item><item><title><![CDATA[Reply to StickC - Serial Problems on Sun, 15 Sep 2019 06:47:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cmisztur" aria-label="Profile: cmisztur">@<bdi>cmisztur</bdi></a> said in <a href="/post/5585">StickC - Serial Problems</a>:</p>
<p dir="auto">Flipped USB-C cable around, now it is showing up in OSX.</p>
<p dir="auto">Going to stick ... ha... with Arduino IDE for now.</p>
<p dir="auto">I'm assuming you are you the lead that came with the Stick?<br />
If the issue pops up again try a new high quality lead as this is a known issue with cheep leads.<br />
Also mark the usbc end so that you know which way around it should be.</p>
]]></description><link>https://community.m5stack.com/post/5589</link><guid isPermaLink="true">https://community.m5stack.com/post/5589</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 15 Sep 2019 06:47:34 GMT</pubDate></item><item><title><![CDATA[Reply to StickC - Serial Problems on Sun, 15 Sep 2019 01:13:28 GMT]]></title><description><![CDATA[<p dir="auto">Flipped USB-C cable around, now it is showing up in OSX.</p>
]]></description><link>https://community.m5stack.com/post/5585</link><guid isPermaLink="true">https://community.m5stack.com/post/5585</guid><dc:creator><![CDATA[cmisztur]]></dc:creator><pubDate>Sun, 15 Sep 2019 01:13:28 GMT</pubDate></item><item><title><![CDATA[Reply to StickC - Serial Problems on Sun, 15 Sep 2019 01:09:15 GMT]]></title><description><![CDATA[<p dir="auto">Tried again on PC, came up as 'USB Serial Device'.  Installed 'FT4222 Mode 3 Device' driver 2.12.0.0.  Got a COM port.  Kind of works.  Mostly it keeps disconnecting/reconnecting.</p>
<p dir="auto">I can no longer see the device on OSX 10.14.6.  Nothing pops up in security about CP driver.</p>
]]></description><link>https://community.m5stack.com/post/5584</link><guid isPermaLink="true">https://community.m5stack.com/post/5584</guid><dc:creator><![CDATA[cmisztur]]></dc:creator><pubDate>Sun, 15 Sep 2019 01:09:15 GMT</pubDate></item></channel></rss>
