<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC Hall Sensor not working]]></title><description><![CDATA[<p dir="auto">You can't read the Hall Sensor on the M5StickC.</p>
<p dir="auto">According to the ESP32 manual the internal hall sensor on the ESP32 is connected to the analog channels on pins GPIO36 and GPIO39.</p>
<p dir="auto">The ESP32 document note reads: "It is also possible to read the internal hall effect sensor via ADC1 by calling dedicated function hall_sensor_read(). Note that even the hall sensor is internal to ESP32, reading from it uses channels 0 and 3 of ADC1 (GPIO 36 and 39). Do not connect anything else to these pins and do not change their configuration."</p>
<p dir="auto">The M5StickC uses pin GPIO39 as the hardware  button pin  B switchingthe stick on and off  (always monitoring for a 6 sec press) , GPIO36 is brought out to the connector at the top of the device and there is no schematic showing it has no internal strings attached ..</p>
]]></description><link>https://community.m5stack.com/topic/1326/m5stickc-hall-sensor-not-working</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:56:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1326.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Sep 2019 22:30:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC Hall Sensor not working on Thu, 03 Oct 2019 17:16:09 GMT]]></title><description><![CDATA[<p dir="auto">It's simple, fill in the code from the example, hold the magnet to the M5stickC and you will see that the readings will change significantly! The magnet is needed strong enough, because The sensor is far away in the device.</p>
]]></description><link>https://community.m5stack.com/post/5806</link><guid isPermaLink="true">https://community.m5stack.com/post/5806</guid><dc:creator><![CDATA[MManiac]]></dc:creator><pubDate>Thu, 03 Oct 2019 17:16:09 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC Hall Sensor not working on Thu, 03 Oct 2019 13:34:49 GMT]]></title><description><![CDATA[<p dir="auto">What is the Hall sensor actually measuring in that example? I dont see any evidence of a changing external magnetic field. Also I wonder if it's a problem that there is also a magnet in the M5StickC case.</p>
]]></description><link>https://community.m5stack.com/post/5803</link><guid isPermaLink="true">https://community.m5stack.com/post/5803</guid><dc:creator><![CDATA[wikistik]]></dc:creator><pubDate>Thu, 03 Oct 2019 13:34:49 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC Hall Sensor not working on Mon, 23 Sep 2019 18:11:20 GMT]]></title><description><![CDATA[<p dir="auto">I'm find this project, and in get date from Hall sensor, using MicroPython and M5 libs:<br />
<a href="https://m5stack.hackster.io/Max-Lavrov/hall-sensor-and-temperature-sensor-in-esp32-934ba8" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.hackster.io/Max-Lavrov/hall-sensor-and-temperature-sensor-in-esp32-934ba8</a></p>
]]></description><link>https://community.m5stack.com/post/5707</link><guid isPermaLink="true">https://community.m5stack.com/post/5707</guid><dc:creator><![CDATA[MManiac]]></dc:creator><pubDate>Mon, 23 Sep 2019 18:11:20 GMT</pubDate></item></channel></rss>
