<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC usb driver not working]]></title><description><![CDATA[<p dir="auto">I was trying to start coding with my newly purchased M5StickC and came across a big problem: I wasn't able to get the usb driver for the USB Type-C cable working so I can program from the Arduino IDE. I went through the suggested steps from the documentation but they didn't fix the problem. Can I have some help? BTW, my Arduino IDE is version 1.8.10 and my laptop is running Windows 7.</p>
]]></description><link>https://community.m5stack.com/topic/1336/m5stickc-usb-driver-not-working</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 20:42:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1336.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Sep 2019 00:16:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC usb driver not working on Tue, 24 Sep 2019 13:24:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wikistik" aria-label="Profile: wikistik">@<bdi>wikistik</bdi></a> I have tried that, but the Windows system seems to be trying to insert a random outdated driver for the USB cable instead of the one you suggested. You're right, though, because on a different Windows 7 computer, I installed the drivers and it started working automatically.</p>
]]></description><link>https://community.m5stack.com/post/5716</link><guid isPermaLink="true">https://community.m5stack.com/post/5716</guid><dc:creator><![CDATA[brain-brawn]]></dc:creator><pubDate>Tue, 24 Sep 2019 13:24:37 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC usb driver not working on Sun, 22 Sep 2019 12:36:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brain-brawn" aria-label="Profile: brain-brawn">@<bdi>brain-brawn</bdi></a> Have you tried installing the FTDI drivers (<a href="https://www.ftdichip.com/FTDrivers.htm" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ftdichip.com/FTDrivers.htm</a>)? I have found that this solved USB connection problems with obsolete versions of Windows in a couple cases.</p>
]]></description><link>https://community.m5stack.com/post/5691</link><guid isPermaLink="true">https://community.m5stack.com/post/5691</guid><dc:creator><![CDATA[wikistik]]></dc:creator><pubDate>Sun, 22 Sep 2019 12:36:52 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC usb driver not working on Sat, 21 Sep 2019 06:14:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brain-brawn" aria-label="Profile: brain-brawn">@<bdi>brain-brawn</bdi></a> Have you tried turning the "C" end around?<br />
Have you tried a different cable?</p>
]]></description><link>https://community.m5stack.com/post/5675</link><guid isPermaLink="true">https://community.m5stack.com/post/5675</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 21 Sep 2019 06:14:57 GMT</pubDate></item></channel></rss>
