<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[isCharging() and getBatteryLevel()]]></title><description><![CDATA[<p dir="auto">The M5 Stack has: M5.Power.isCharging() and M5.Power.getBatteryLevel(), but Power (from M5Stack.h) is not in the M5 object for the stick (M5Stick.h).  Is it possible to determine if the M5 stick is changing, and also determine what the battery level (percentage charged) is?</p>
]]></description><link>https://community.m5stack.com/topic/1361/ischarging-and-getbatterylevel</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:37:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1361.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Oct 2019 02:54:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to isCharging() and getBatteryLevel() on Mon, 13 Jan 2020 23:32:44 GMT]]></title><description><![CDATA[<p dir="auto">I use the battery voltage to try and work out a sensible idea of battery level. Anything equal or over 4.1 can be considered full, less than 3.4 is pretty much dead, and 3.7 is generally where it'll spend most of it's time. It's not a linear drop off, so it will take some calculations to try and get it accurate around the 3.6 to 3.8 volt range. This is probably why the M5Stack library only gives 0/25/50/75/100 battery levels.</p>
<p dir="auto">I then use battery current to know if it's charging, discharging or fully charged. By getting the value from M5.Axp.GetBatCurrent() if you see a negative value, it's discharging, a positive value is charging and a zero value means fully charged while plugged in. The values returned will give you an idea of how much current is being drained from the battery in mA, or indeed how much current is being used to charge the battery, all in realtime. On the M5StickC it would be 85mA typically when charging.</p>
]]></description><link>https://community.m5stack.com/post/7029</link><guid isPermaLink="true">https://community.m5stack.com/post/7029</guid><dc:creator><![CDATA[Maxrom]]></dc:creator><pubDate>Mon, 13 Jan 2020 23:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to isCharging() and getBatteryLevel() on Mon, 07 Oct 2019 12:12:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeffb" aria-label="Profile: jeffb">@<bdi>jeffb</bdi></a> said in <a href="/post/5822">isCharging() and getBatteryLevel()</a>:</p>
<p dir="auto">Well, I wish I could.  M5.Power is in <strong>M5Stack.h</strong> and is only available for the <strong>M5 Stack</strong>.</p>
<p dir="auto">I have a <strong>M5 Stick</strong> and have to use <strong>M5Stick.h</strong>, and <em>M5.Power is not defined and is not available in M5Stick.h</em></p>
<p dir="auto">Oh, i missed that you have the Stick. :-(<br />
But i think the routines posted here are MUTCH better than the one in the Lib.<br />
The BatteryStatus gives only 100%, 75%, 50%, 25%, .... :-(</p>
<p dir="auto">Bye</p>
]]></description><link>https://community.m5stack.com/post/5852</link><guid isPermaLink="true">https://community.m5stack.com/post/5852</guid><dc:creator><![CDATA[mikeljo]]></dc:creator><pubDate>Mon, 07 Oct 2019 12:12:39 GMT</pubDate></item><item><title><![CDATA[Reply to isCharging() and getBatteryLevel() on Sun, 06 Oct 2019 07:01:45 GMT]]></title><description><![CDATA[<p dir="auto">Nice work guys is cracking this issue. I hope you guys solve it in a reliable way.</p>
<p dir="auto">Please excuse this foolish comment as I dont know enough but</p>
<p dir="auto">Isn't <strong>GetVapsData()</strong> used to measure how much draw from the battery is made by running software?</p>
]]></description><link>https://community.m5stack.com/post/5843</link><guid isPermaLink="true">https://community.m5stack.com/post/5843</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 06 Oct 2019 07:01:45 GMT</pubDate></item><item><title><![CDATA[Reply to isCharging() and getBatteryLevel() on Sat, 05 Oct 2019 23:37:42 GMT]]></title><description><![CDATA[<p dir="auto">correction, it would be:</p>
<pre><code>double getBatteryLevel(void)
  uint16_t vbatData = M5.Axp.GetVbatData();
  double vbat = vbatData * 1.1 / 1000;
  return 100.0 * ((vbat - 3.0) / (4.07 - 3.0));
<p dir="auto">...what would be a better implementation for getBatteryLevel()?</p>
]]></description><link>https://community.m5stack.com/post/5841</link><guid isPermaLink="true">https://community.m5stack.com/post/5841</guid><dc:creator><![CDATA[JeffB]]></dc:creator><pubDate>Sat, 05 Oct 2019 23:37:42 GMT</pubDate></item><item><title><![CDATA[Reply to isCharging() and getBatteryLevel() on Sat, 05 Oct 2019 23:28:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the tip <a class="plugin-mentions-user plugin-mentions-a" href="/user/majrooo" aria-label="Profile: majrooo">@<bdi>majrooo</bdi></a> .  I have been playing around w/the Axp class,  and I'm closer, but not fully there.  From your reply (and the PowerWake example), it sounds like GetVapsData() is supposed to return the overall capacity, and GetVbatData() is supposed to return the current voltage, but that's not whatI'm seeing though.  Here is a sample:</p>
<pre><code>#include &lt;M5StickC.h&gt;
RTC_TimeTypeDef RTC_TimeStruct;
void displayInfo(void);
void setCursorToLine(int lineNumber);
void setup()
  M5.begin();
  M5.Axp.begin();
  RTC_TimeTypeDef timeStruct;
  timeStruct.Hours = 0;
  timeStruct.Minutes = 0;
  timeStruct.Seconds = 0;
  M5.Rtc.SetTime(&amp;timeStruct);
  M5.Lcd.setRotation(1);
void loop()
  M5.Lcd.fillScreen(BLACK);
  displayInfo();
  delay(1000);
  uint16_t vbatData = M5.Axp.GetVbatData();  // docs: "Get the battery voltage value"
  setCursorToLine(1);
  M5.Lcd.printf("vbat: %.3f V    ", vbat);
  // charging: 4.188 V
  // unplugged: 4.068 V (fully charged)
  // unplugged: 3.068 V (45 minutes later, about to turn off)
  uint16_t vapsData = M5.Axp.GetVapsData();  // docs: "Get battery capacity"
  double vaps = vapsData * 1.4 / 1000;
  setCursorToLine(2);
  M5.Lcd.printf("vaps: %.3f V    ", vaps);
  // charging: 4.971 V
  // unplugged: 3.066 V (45 minutes later, about to turn off)
  double batteryLevel = 100.0 * ((vaps - 3.0) / (vbat - 3.0));
  setCursorToLine(3);
  M5.Lcd.printf("batteryLevel: %.1f%%    ", batteryLevel);
  M5.Rtc.GetTime(&amp;RTC_TimeStruct);
  setCursorToLine(4);
  M5.Lcd.printf("%02d:%02d:%02d", RTC_TimeStruct.Hours, RTC_TimeStruct.Minutes, RTC_TimeStruct.Seconds);
  const int X_LOCATION = 5;
  const int Y_LOCATION = 0;
  const int LINE_HEIGHT = 20;
  M5.Lcd.setCursor(X_LOCATION, Y_LOCATION + ((lineNumber - 1) * LINE_HEIGHT), 2);
<p dir="auto">When charging, I'm getting:</p>
<pre><code>  uint16_t vbatData = M5.Axp.GetVbatData();   // docs: "Get the battery voltage value"
<p dir="auto">After fully charge and then disconnected, I get:</p>
<p dir="auto">..and later on, when the battery is around 3V and just about to power off, I had:</p>
<p dir="auto">I was expecting the value from GetVapsData() to remain constant, but as you can see, vbat tracked almost 1:1 with vaps.</p>
<p dir="auto">So I then hard-coded the "max battery capacity" value to 4.07 and changed batteryLevel to:</p>
<pre><code>  //double batteryLevel = 100.0 * ((vaps - 3.0) / (vbat - 3.0));
  double batteryLevel = 100.0 * ((vaps - 3.0) / (4.07 - 3.0));
  setCursorToLine(3);
<p dir="auto">...and this works, but I don't like having to hard-code the max-battery-capacity value to 4.07 and would rather there was a way to programmatically get this value.</p>
<p dir="auto">I feel like there must be a way to do this, but I'm not seeing how with the methods in Axp.</p>
<p dir="auto">If I were to refactor my current code for batteryLevel into a function, it would be:</p>
  return 100.0 * ((vaps - 3.0) / (4.07 - 3.0));
<p dir="auto">What would be a better implementation for getBatteryLevel()?</p>
<p dir="auto">Thanks,</p>
<p dir="auto">Jeff</p>
]]></description><link>https://community.m5stack.com/post/5840</link><guid isPermaLink="true">https://community.m5stack.com/post/5840</guid><dc:creator><![CDATA[JeffB]]></dc:creator><pubDate>Sat, 05 Oct 2019 23:28:35 GMT</pubDate></item><item><title><![CDATA[Reply to isCharging() and getBatteryLevel() on Fri, 04 Oct 2019 20:16:50 GMT]]></title><description><![CDATA[<p dir="auto">Take look at this example:<br />
<a href="https://github.com/m5stack/M5StickC/tree/master/examples/Advanced/AXP192/PowerWake" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5StickC/tree/master/examples/Advanced/AXP192/PowerWake</a></p>
<p dir="auto">function 'M5.Axp.GetVapsData()' can be used for what you need. When value is above 4.5V it's charging.<br />
function M5.Axp.GetVbatData() will show you battery level.</p>
]]></description><link>https://community.m5stack.com/post/5825</link><guid isPermaLink="true">https://community.m5stack.com/post/5825</guid><dc:creator><![CDATA[majrooo]]></dc:creator><pubDate>Fri, 04 Oct 2019 20:16:50 GMT</pubDate></item><item><title><![CDATA[Reply to isCharging() and getBatteryLevel() on Fri, 04 Oct 2019 15:07:48 GMT]]></title><description><![CDATA[<p dir="auto">Well, I wish I could.  M5.Power is in <strong>M5Stack.h</strong> and is only available for the <strong>M5 Stack</strong>.</p>
]]></description><link>https://community.m5stack.com/post/5822</link><guid isPermaLink="true">https://community.m5stack.com/post/5822</guid><dc:creator><![CDATA[JeffB]]></dc:creator><pubDate>Fri, 04 Oct 2019 15:07:48 GMT</pubDate></item><item><title><![CDATA[Reply to isCharging() and getBatteryLevel() on Fri, 04 Oct 2019 08:29:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">just do "uint8_t Bat_Level = M5.Power.getBatteryLevel()" and then you have it.</p>
]]></description><link>https://community.m5stack.com/post/5814</link><guid isPermaLink="true">https://community.m5stack.com/post/5814</guid><dc:creator><![CDATA[mikeljo]]></dc:creator><pubDate>Fri, 04 Oct 2019 08:29:30 GMT</pubDate></item></channel></rss>
