<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Heart rate unit with M5Stick]]></title><description><![CDATA[<p dir="auto">Hello! My heart rate unit is working with m5stack, but it dosen't work with m5stick. Code is the same. When I turn on m5stick sensor flashes for about 0.5 second and then remain dim, so serial monitor return 0 for forever. What is the problem? Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/1363/heart-rate-unit-with-m5stick</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 01:25:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1363.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Oct 2019 10:53:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Heart rate unit with M5Stick on Sun, 06 Oct 2019 18:25:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ruslancc" aria-label="Profile: ruslancc">@<bdi>ruslancc</bdi></a> Unknown but I have fixed that now.<br />
It could be that the M5Stick can not provide enough power for the heart rate monitor.<br />
You could try connecting one of these<br />
<a href="https://m5stack.com/collections/m5-accessory/products/grove-t-connector-5pcs-a-pack" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/collections/m5-accessory/products/grove-t-connector-5pcs-a-pack</a></p>
<p dir="auto"><img src="https://cdn.shopify.com/s/files/1/0056/7689/2250/products/GROVE-T_1200x1200.jpg?v=1566377200" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">between the Stick and the heart rate monitor and use the other connection to provide an additional power supply for the monitor.</p>
]]></description><link>https://community.m5stack.com/post/5849</link><guid isPermaLink="true">https://community.m5stack.com/post/5849</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 06 Oct 2019 18:25:09 GMT</pubDate></item><item><title><![CDATA[Reply to Heart rate unit with M5Stick on Sun, 06 Oct 2019 18:04:35 GMT]]></title><description><![CDATA[<p dir="auto">Why is this marked as solved if it isn't working?</p>
]]></description><link>https://community.m5stack.com/post/5848</link><guid isPermaLink="true">https://community.m5stack.com/post/5848</guid><dc:creator><![CDATA[RuslanCC]]></dc:creator><pubDate>Sun, 06 Oct 2019 18:04:35 GMT</pubDate></item><item><title><![CDATA[Reply to Heart rate unit with M5Stick on Fri, 04 Oct 2019 14:39:47 GMT]]></title><description><![CDATA[<p dir="auto">I use code from here:<br />
<a href="https://m5stack.com/products/mini-heart-unit" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/products/mini-heart-unit</a><br />
Arduino IDE</p>
]]></description><link>https://community.m5stack.com/post/5821</link><guid isPermaLink="true">https://community.m5stack.com/post/5821</guid><dc:creator><![CDATA[RuslanCC]]></dc:creator><pubDate>Fri, 04 Oct 2019 14:39:47 GMT</pubDate></item><item><title><![CDATA[Reply to Heart rate unit with M5Stick on Fri, 04 Oct 2019 12:11:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/ruslancc" aria-label="Profile: RuslanCC">@<bdi>RuslanCC</bdi></a> could you tell us which language your programming in and perhaps share your code with us</p>
]]></description><link>https://community.m5stack.com/post/5816</link><guid isPermaLink="true">https://community.m5stack.com/post/5816</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Fri, 04 Oct 2019 12:11:57 GMT</pubDate></item></channel></rss>
