<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Charging the battery]]></title><description><![CDATA[<p dir="auto">How long should it take to charge the core battery fully with a 2A charger?</p>
]]></description><link>https://community.m5stack.com/topic/137/charging-the-battery</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 22:33:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/137.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Mar 2018 17:59:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Charging the battery on Thu, 29 Mar 2018 01:48:09 GMT]]></title><description><![CDATA[<p dir="auto">I am charging it with the ipad 1 charger. I have a meter and the wall wart is normally 5v, but the output amps is .3A and on the faces that i have it is .17A. It charges my other things just fine. I don't know why the amp draw is so low.</p>
]]></description><link>https://community.m5stack.com/post/671</link><guid isPermaLink="true">https://community.m5stack.com/post/671</guid><dc:creator><![CDATA[km4hpk]]></dc:creator><pubDate>Thu, 29 Mar 2018 01:48:09 GMT</pubDate></item><item><title><![CDATA[Reply to Charging the battery on Fri, 23 Mar 2018 19:11:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/km4hpk" aria-label="Profile: km4hpk">@<bdi>km4hpk</bdi></a></p>
<p dir="auto">Note these points:</p>
<p dir="auto"><strong>Official recommendations for use:</strong></p>
<p dir="auto">Power input to M5Stack - 5 - 5.5 V @ 500 mA - is the official recommendation.<br />
Short USB cable is the official recommendation.<br />
Arduino IDE upload speed - 119,200 - is the official recommendation.</p>
<p dir="auto">It may be you are not getting enough power to your M5Stack.</p>
<p dir="auto">How is it connected to USB ?</p>
<p dir="auto">When u charge it is it getting - 5 - 5.5 V @ 500 mA  ?  Under 5 volts is below spec.</p>
<p dir="auto">If using a hub, disconnect other devices AND connect a power supply to the USB hub. (This makes a BIG difference - I have tested it using USB meter.)</p>
<p dir="auto">You can test the USB power supply to the M5 using a USB power meter.</p>
<p dir="auto">If those measures do not resolve it, then test on another PC using a different USB port / or get an adaptor and charge it directly using a Raspberry PI compatible transformer as per the specs above.</p>
<p dir="auto">When the unit is turned off there is some low level power use still occurring so the battery can drain over time.  For this reason the Battery Module is a good addition - 150 mAh battery (internal batt) vs 850 mAh battery (batt module).</p>
]]></description><link>https://community.m5stack.com/post/639</link><guid isPermaLink="true">https://community.m5stack.com/post/639</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Fri, 23 Mar 2018 19:11:53 GMT</pubDate></item><item><title><![CDATA[Reply to Charging the battery on Thu, 22 Mar 2018 22:02:55 GMT]]></title><description><![CDATA[<p dir="auto">I power it on to show my friends the test program about 2 times and the power it off. Some time later while it is powered off it dies within 6 hours. I charge it with my 10watt charger.</p>
]]></description><link>https://community.m5stack.com/post/629</link><guid isPermaLink="true">https://community.m5stack.com/post/629</guid><dc:creator><![CDATA[km4hpk]]></dc:creator><pubDate>Thu, 22 Mar 2018 22:02:55 GMT</pubDate></item><item><title><![CDATA[Reply to Charging the battery on Mon, 19 Mar 2018 16:27:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/km4hpk" aria-label="Profile: km4hpk">@<bdi>km4hpk</bdi></a></p>
<p dir="auto">How long does it stay charged roughly ?<br />
Is it getting enough power when you charge it ?<br />
How are u charging it ?</p>
]]></description><link>https://community.m5stack.com/post/619</link><guid isPermaLink="true">https://community.m5stack.com/post/619</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Mon, 19 Mar 2018 16:27:25 GMT</pubDate></item><item><title><![CDATA[Reply to Charging the battery on Mon, 19 Mar 2018 16:12:46 GMT]]></title><description><![CDATA[<p dir="auto">Then my battery must be defective. It doesnt stay charged very long</p>
]]></description><link>https://community.m5stack.com/post/618</link><guid isPermaLink="true">https://community.m5stack.com/post/618</guid><dc:creator><![CDATA[km4hpk]]></dc:creator><pubDate>Mon, 19 Mar 2018 16:12:46 GMT</pubDate></item><item><title><![CDATA[Reply to Charging the battery on Mon, 19 Mar 2018 05:59:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/km4hpk" aria-label="Profile: km4hpk">@<bdi>km4hpk</bdi></a></p>
<p dir="auto">Hi km4hpk,</p>
<p dir="auto">As a rough indicator with variance based on individual conditions, I'd say around 40 mins.....</p>
]]></description><link>https://community.m5stack.com/post/614</link><guid isPermaLink="true">https://community.m5stack.com/post/614</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Mon, 19 Mar 2018 05:59:53 GMT</pubDate></item></channel></rss>
