<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Env Hat Temperature]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Finding that the temperature gotten from the ENV Hat is way out, showing 28c when my room is at 18c according to thermostat.</p>
<p dir="auto">What is going on ?</p>
]]></description><link>https://community.m5stack.com/topic/1382/env-hat-temperature</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 11:27:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1382.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Oct 2019 16:34:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Env Hat Temperature on Mon, 14 Oct 2019 18:12:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/5924">Env Hat Temperature</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfny" aria-label="Profile: mfny">@<bdi>mfny</bdi></a> Could be many things including heat from the stick c.<br />
How are you coding it?</p>
<p dir="auto">I am using the provided built in example in UI flow..</p>
]]></description><link>https://community.m5stack.com/post/5967</link><guid isPermaLink="true">https://community.m5stack.com/post/5967</guid><dc:creator><![CDATA[mfny]]></dc:creator><pubDate>Mon, 14 Oct 2019 18:12:53 GMT</pubDate></item><item><title><![CDATA[Reply to Env Hat Temperature on Sat, 12 Oct 2019 18:44:44 GMT]]></title><description><![CDATA[<p dir="auto">Using the provided example in UIflow.</p>
]]></description><link>https://community.m5stack.com/post/5926</link><guid isPermaLink="true">https://community.m5stack.com/post/5926</guid><dc:creator><![CDATA[mfny]]></dc:creator><pubDate>Sat, 12 Oct 2019 18:44:44 GMT</pubDate></item><item><title><![CDATA[Reply to Env Hat Temperature on Sat, 12 Oct 2019 17:11:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfny" aria-label="Profile: mfny">@<bdi>mfny</bdi></a> Could be many things including heat from the stick c.<br />
]]></description><link>https://community.m5stack.com/post/5924</link><guid isPermaLink="true">https://community.m5stack.com/post/5924</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 12 Oct 2019 17:11:07 GMT</pubDate></item></channel></rss>
