<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MPU6886]]></title><description><![CDATA[<p dir="auto">Hi, I'm having trouble with the MPU6886 demo.</p>
<p dir="auto">The Roll and Pitch calculations are stable the Yaw is constantly incrementing at around 10 degrees per second.</p>
<p dir="auto">I've done quite a lot of searching. I've implemented a little routine to zero the gryoscope at power up (not temperature compensate right now) but holds the Gryo(x,y,z) at around 0 while stationary on my desk.</p>
<p dir="auto">The changes haven't made any difference. The Yaw does react to movement in the Yaw plane, but there is an underlying increment of around 10 degrees per second.</p>
<p dir="auto">Any advice would be greatly welcome as I only bought the M5Stack Grey to use the IMU to implement a rowing stroke meter.</p>
]]></description><link>https://community.m5stack.com/topic/1384/mpu6886</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 07:57:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1384.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Oct 2019 10:47:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MPU6886 on Sun, 09 Feb 2020 22:10:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/coulddobetter" aria-label="Profile: coulddobetter">@<bdi>coulddobetter</bdi></a>  Can u send your code please I need to sense if a door its open or not .The problem is that how I use conditionals if to do this</p>
]]></description><link>https://community.m5stack.com/post/7336</link><guid isPermaLink="true">https://community.m5stack.com/post/7336</guid><dc:creator><![CDATA[Bryam]]></dc:creator><pubDate>Sun, 09 Feb 2020 22:10:36 GMT</pubDate></item></channel></rss>
