<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[no flash possible after fw 1.4.1.sg on M5GO]]></title><description><![CDATA[<p dir="auto">Hello everyone,<br />
It's my first M5Stack,<br />
after a flash with M5burn with a new M5GO with the <a href="http://1.4.1.sg" target="_blank" rel="noopener noreferrer nofollow ugc">1.4.1.sg</a> FW, its work fine with <a href="http://flow01.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">http://flow01.m5stack.com/</a> but i can't reflash (or Erase) with a older 1.4.0 FW :<br />
can't connect with USB port (but USB31 is here)<br />
The screen go black, it's beep every 1s, but nothing</p>
<p dir="auto">Error message :</p>
<pre><code class="language-(txt)">esptool.py v2.5.0
Serial port COM31
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to Espressif device: Invalid head of packet (0x30)
Finished
<p dir="auto">Any idea ?</p>
]]></description><link>https://community.m5stack.com/topic/1397/no-flash-possible-after-fw-1-4-1-sg-on-m5go</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 07:42:03 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1397.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Oct 2019 17:07:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to no flash possible after fw 1.4.1.sg on M5GO on Wed, 16 Oct 2019 21:19:12 GMT]]></title><description><![CDATA[<p dir="auto">Try to reflash with <a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a>, it also has erase option</p>
]]></description><link>https://community.m5stack.com/post/6016</link><guid isPermaLink="true">https://community.m5stack.com/post/6016</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Wed, 16 Oct 2019 21:19:12 GMT</pubDate></item><item><title><![CDATA[Reply to no flash possible after fw 1.4.1.sg on M5GO on Wed, 16 Oct 2019 18:14:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phd0" aria-label="Profile: phd0">@<bdi>phd0</bdi></a></p>
<p dir="auto">Ok on old computer, delete the driver and shut down the computer into full power off.<br />
Start computer and fresh install driver, then shut pc off again when finished installing.<br />
Restart pc and try to connect. the driver can be problematic at times how ever if you have an arduino of usb&gt;UART you can bypass the inbuilt adapter to program.</p>
]]></description><link>https://community.m5stack.com/post/6012</link><guid isPermaLink="true">https://community.m5stack.com/post/6012</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 16 Oct 2019 18:14:42 GMT</pubDate></item><item><title><![CDATA[Reply to no flash possible after fw 1.4.1.sg on M5GO on Wed, 16 Oct 2019 18:07:21 GMT]]></title><description><![CDATA[<p dir="auto">thanks for the fast response. Yes Windows7 pro, this the good driver<br />
test with :</p>
<li>another cable (in 115200 or 921600 baud ) : not ok</li>
<li>another PC in Win10 and new install drivers + M5burner (in 115200 baud) : <strong>OK</strong></li>
<p dir="auto">i'm happy !</p>
]]></description><link>https://community.m5stack.com/post/6010</link><guid isPermaLink="true">https://community.m5stack.com/post/6010</guid><dc:creator><![CDATA[phd0]]></dc:creator><pubDate>Wed, 16 Oct 2019 18:07:21 GMT</pubDate></item><item><title><![CDATA[Reply to no flash possible after fw 1.4.1.sg on M5GO on Wed, 16 Oct 2019 17:45:43 GMT]]></title><description><![CDATA[<p dir="auto">Step 1 - turn the connection that plugs into the M5Stack upside down and try again,<br />
Step 2 - Try a new USBC lead,<br />
Step 3 try a different computer.</p>
<p dir="auto">I'm assuming that you are using a windows computer as it says Com31.</p>
]]></description><link>https://community.m5stack.com/post/6009</link><guid isPermaLink="true">https://community.m5stack.com/post/6009</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 16 Oct 2019 17:45:43 GMT</pubDate></item></channel></rss>
