<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC does not scan I2C sensor at (0,26) pins (Hat pins)]]></title><description><![CDATA[<p dir="auto">There is limited workable G0 pin at M5StickC in the current version of the hardware!<br />
It's could not possible to scan I2C sensor at (0,26) pins<br />
At the same time, there is no problem for (32,33) or (32,26) pins<br />
There was not such a problem in the older version of hardware M2StickC<br />
This problem take place just for some kinds of I2C sensors, f.e. SGP30</p>
]]></description><link>https://community.m5stack.com/topic/1415/m5stickc-does-not-scan-i2c-sensor-at-0-26-pins-hat-pins</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:51:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1415.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Oct 2019 07:42:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC does not scan I2C sensor at (0,26) pins (Hat pins) on Tue, 30 Mar 2021 23:55:10 GMT]]></title><description><![CDATA[<p dir="auto">Same problem here.</p>
]]></description><link>https://community.m5stack.com/post/13335</link><guid isPermaLink="true">https://community.m5stack.com/post/13335</guid><dc:creator><![CDATA[Genio]]></dc:creator><pubDate>Tue, 30 Mar 2021 23:55:10 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC does not scan I2C sensor at (0,26) pins (Hat pins) on Tue, 10 Mar 2020 01:12:48 GMT]]></title><description><![CDATA[<p dir="auto">Is there any new knowledge about this issue. My SGP30 Sensor holds up the M5StickC from even starting up when used via the HAT-Connector on G0, G26 ... Is there a workaround, like using the Grove Port?</p>
]]></description><link>https://community.m5stack.com/post/7708</link><guid isPermaLink="true">https://community.m5stack.com/post/7708</guid><dc:creator><![CDATA[bigjim991]]></dc:creator><pubDate>Tue, 10 Mar 2020 01:12:48 GMT</pubDate></item></channel></rss>
