<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;Download&quot;, and now I cannot connect to M5StickC]]></title><description><![CDATA[<p dir="auto">If I write any code in M5Flow 1.41-beta OR 1.32 and then "download" the code and run it on my M5StickC, there doesn't seem to be any way to get back to using M5Flow. The device appears to be completely disconnected from the network, not responding to further "download" commands, and can't even run code.</p>
<p dir="auto"><strong>Solved</strong><br />
When the device reboots, instead of allowing it to reboot and run the downloaded code, hold down the reset button AND the button B at the same time, then the device will go back into a monitoring mode.<br />
Is this documented anywhere?</p>
]]></description><link>https://community.m5stack.com/topic/1418/download-and-now-i-cannot-connect-to-m5stickc</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 17:00:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1418.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Oct 2019 10:34:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;Download&quot;, and now I cannot connect to M5StickC on Fri, 25 Oct 2019 14:10:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thrasher" aria-label="Profile: thrasher">@<bdi>thrasher</bdi></a> I wouldn’t worry to much as I keep forgetting the sequence</p>
]]></description><link>https://community.m5stack.com/post/6134</link><guid isPermaLink="true">https://community.m5stack.com/post/6134</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 25 Oct 2019 14:10:26 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Download&quot;, and now I cannot connect to M5StickC on Fri, 25 Oct 2019 11:54:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thrasher" aria-label="Profile: thrasher">@<bdi>thrasher</bdi></a> Yes that's what I was doing, and thought there must be a better way.<br />
There are a couple of operations that require the 'download' method of installation, and will not work in the 'play' mode.</p>
]]></description><link>https://community.m5stack.com/post/6132</link><guid isPermaLink="true">https://community.m5stack.com/post/6132</guid><dc:creator><![CDATA[chiefpad]]></dc:creator><pubDate>Fri, 25 Oct 2019 11:54:31 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Download&quot;, and now I cannot connect to M5StickC on Fri, 25 Oct 2019 11:00:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>  really? I probably missed it, was too hasty to try out hardware :]</p>
]]></description><link>https://community.m5stack.com/post/6131</link><guid isPermaLink="true">https://community.m5stack.com/post/6131</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Fri, 25 Oct 2019 11:00:35 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Download&quot;, and now I cannot connect to M5StickC on Fri, 25 Oct 2019 10:57:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thrasher" aria-label="Profile: thrasher">@<bdi>thrasher</bdi></a> err I still have to log this in my books but it was on one of the official stick documents.</p>
]]></description><link>https://community.m5stack.com/post/6130</link><guid isPermaLink="true">https://community.m5stack.com/post/6130</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 25 Oct 2019 10:57:53 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Download&quot;, and now I cannot connect to M5StickC on Fri, 25 Oct 2019 10:38:16 GMT]]></title><description><![CDATA[<p dir="auto">Nice, good to know,<br />
havent seen it documented anywhere tho.<br />
I always used to "run" code instead of download it with stickC, but once I downloaded it, I simply re-firmwared device.</p>
]]></description><link>https://community.m5stack.com/post/6129</link><guid isPermaLink="true">https://community.m5stack.com/post/6129</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Fri, 25 Oct 2019 10:38:16 GMT</pubDate></item></channel></rss>
