<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC &amp; Sensor SHT 31]]></title><description><![CDATA[<p dir="auto">Hello, how can I integrate my SHT31 sensor into the M5StickC via Grove ?<br />
Here is my code from the Pycom Wipy with which the SHT runs perfectly.</p>
<p dir="auto"><a href="http://Main.py" target="_blank" rel="noopener noreferrer nofollow ugc">Main.py</a><br />
if (Sensorwahl) == 'sht31':</p>
<pre><code>i2c = I2C(0, I2C.MASTER, baudrate=100000)
sensor = sht31.SHT31(i2c, addr=0x44)
temp_humi = sensor.get_temp_humi()
time.sleep(0.6)
pycom.rgbled(0xff007f) # magenta
pycom.heartbeat(False) #Lampe ausschalten um Energie zu sparen
Temp1 = round(temp_humi[0],2)
Feuchte1 = round(temp_humi[1],2)
time.sleep(1)
print('----------------------------------------------------------------------')
print("Ohne Runden = Temperature: {} °C | Humidity: {} %".format(temp_humi[0], temp_humi[1]))
#Übergabe der Sensorwerte---------------------------------------
Temp1 = (Temp1 + 0) #Übergabe und Differenzeingabe
Feuchte1 = (Feuchte1 + 0) #Übergabe und Differenzeingabe
<p dir="auto"><a href="http://sht31.py" target="_blank" rel="noopener noreferrer nofollow ugc">sht31.py</a><br />
from machine import I2C<br />
import time</p>
<p dir="auto">R_HIGH   = const(1)<br />
R_MEDIUM = const(2)<br />
R_LOW    = const(3)</p>
<p dir="auto">class SHT31(object):<br />
"""<br />
Diese Klasse implementiert eine Schnittstelle zur SHT31 Temperatur und Luftfeuchtigkeit.<br />
Sensor von Sensirion.<br />
"""<br />
# Diese statische Karte hilft, den Heap und die Programmlogik sauber zu halten.<br />
_map_cs_r = {<br />
True: {<br />
R_HIGH : b'\x2c\x06',<br />
R_MEDIUM : b'\x2c\x0d',<br />
R_LOW: b'\x2c\x10'<br />
},<br />
False: {<br />
R_HIGH : b'\x24\x00',<br />
R_MEDIUM : b'\x24\x0b',<br />
R_LOW: b'\x24\x16'<br />
}<br />
<pre><code>def __init__(self, i2c, addr=0x44):
    Initialisiert ein Sensorobjekt auf dem angegebenen I2C-Bus, auf das von der
    angegebene Adresse.
    if i2c == None or i2c.__class__ != I2C:
        raise ValueError('I2C-Objekt als Argument benötigt!')
    self._i2c = i2c
    self._addr = addr
def _send(self, buf):
    Sendet das angegebene Pufferobjekt über I2C an den Sensor.
    self._i2c.writeto(self._addr, buf)
def _recv(self, count):
    Lesen von Bytes vom Sensor über I2C. Die Anzahl der Bytes kann angegeben werden.
    als Argument.
    Liefert ein Bytearray für das Ergebnis.
    return self._i2c.readfrom(self._addr, count)
def _raw_temp_humi(self, r=R_HIGH, cs=True):
    Lesen Sie die Rohtemperatur und Luftfeuchtigkeit vom Sensor ab und überspringen Sie CRC. Überprüfung.
    Liefert ein Tupel für beide Werte in dieser Reihenfolge.
    if r not in (R_HIGH, R_MEDIUM, R_LOW):
        raise ValueError('Falscher Wiederholbarkeitswert angegeben!')
    self._send(self._map_cs_r[cs][r])
    time.sleep_ms(50)
    raw = self._recv(6)
    return (raw[0] &lt;&lt; 8) + raw[1], (raw[3] &lt;&lt; 8) + raw[4]
def get_temp_humi(self, resolution=R_HIGH, clock_stretch=True, celsius=True):
    Lesen Sie die Temperatur in Grad Celsius oder Fahrenheit und relativ dazu ab.
    Feuchtigkeit. Auflösung und Taktverlängerung können festgelegt werden.
    t, h = self._raw_temp_humi(resolution, clock_stretch)
    if celsius:
        temp = -45 + (175 * (t / 65535.0))
    else:
        temp = -49 + (315 * (t / 65535.0))
    return temp, 100 * (h / 65535.0)
]]></description><link>https://community.m5stack.com/topic/1419/m5stickc-sensor-sht-31</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 23:50:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1419.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Oct 2019 12:40:21 GMT</pubDate><ttl>60</ttl></channel></rss>
