<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HPWR for external peripherals?]]></title><description><![CDATA[<p dir="auto">I have a project where I need to power some 12V devices; what would be a good way to achieve this? I see the HPWR label but which pins would I use as the M5Bottom re-assigns them (and the base26 has 2 set as R2/T2 with the 3rd as Vin). So far I’m thinking attach a header to base 26 then use the Vin pin and a ground pin and maybe use another for the logic.</p>
]]></description><link>https://community.m5stack.com/topic/1430/hpwr-for-external-peripherals</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 10:22:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1430.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Oct 2019 03:45:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HPWR for external peripherals? on Thu, 31 Oct 2019 05:34:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashwindec11" aria-label="Profile: ashwindec11">@<bdi>ashwindec11</bdi></a> yes, the motors are 12v and are fed from the 12v side of the LM2596SX, the logic and core are fed from the 5v side of the LM2596SX</p>
]]></description><link>https://community.m5stack.com/post/6219</link><guid isPermaLink="true">https://community.m5stack.com/post/6219</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 31 Oct 2019 05:34:19 GMT</pubDate></item><item><title><![CDATA[Reply to HPWR for external peripherals? on Wed, 30 Oct 2019 20:51:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a><br />
Ah okay, so what does HPWR do? And aren’t the motors 12V?</p>
]]></description><link>https://community.m5stack.com/post/6217</link><guid isPermaLink="true">https://community.m5stack.com/post/6217</guid><dc:creator><![CDATA[ashwindec11]]></dc:creator><pubDate>Wed, 30 Oct 2019 20:51:38 GMT</pubDate></item><item><title><![CDATA[Reply to HPWR for external peripherals? on Wed, 30 Oct 2019 20:29:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashwindec11" aria-label="Profile: ashwindec11">@<bdi>ashwindec11</bdi></a> said in <a href="/post/6214">HPWR for external peripherals?</a>:</p>
<p dir="auto">Ah okay, so how does the stepper module work for power? Also what is HPWR?</p>
<p dir="auto">The modules use an LM2596sx to drop the power from 12 to 5v befor feeding it to the 5v pin.</p>
]]></description><link>https://community.m5stack.com/post/6215</link><guid isPermaLink="true">https://community.m5stack.com/post/6215</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 30 Oct 2019 20:29:22 GMT</pubDate></item><item><title><![CDATA[Reply to HPWR for external peripherals? on Wed, 30 Oct 2019 20:22:38 GMT]]></title><description><![CDATA[<p dir="auto">Ah okay, so how does the stepper module work for power? Also what is HPWR?</p>
]]></description><link>https://community.m5stack.com/post/6214</link><guid isPermaLink="true">https://community.m5stack.com/post/6214</guid><dc:creator><![CDATA[ashwindec11]]></dc:creator><pubDate>Wed, 30 Oct 2019 20:22:38 GMT</pubDate></item><item><title><![CDATA[Reply to HPWR for external peripherals? on Wed, 30 Oct 2019 20:21:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashwindec11" aria-label="Profile: ashwindec11">@<bdi>ashwindec11</bdi></a> No, the input to the core cannot be powered from 12v it is only a 5v or a 3.3v.<br />
to use 12v you need to provide an additional adapter. the stackable module have built in power adapters to take the 12v and supply 5 volt to the M5Stack bus</p>
]]></description><link>https://community.m5stack.com/post/6213</link><guid isPermaLink="true">https://community.m5stack.com/post/6213</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 30 Oct 2019 20:21:19 GMT</pubDate></item><item><title><![CDATA[Reply to HPWR for external peripherals? on Wed, 30 Oct 2019 16:25:22 GMT]]></title><description><![CDATA[<p dir="auto">That could be a way but I want to keep everything together (otherwise why use something nice and concise like M5Stack when I could just use a breadboard with wires everywhere and multiple power inputs). The input for the core can be 12V so I thought why not use that as the input for the other stuff (heater, fan, motor, etc).</p>
]]></description><link>https://community.m5stack.com/post/6210</link><guid isPermaLink="true">https://community.m5stack.com/post/6210</guid><dc:creator><![CDATA[ashwindec11]]></dc:creator><pubDate>Wed, 30 Oct 2019 16:25:22 GMT</pubDate></item><item><title><![CDATA[Reply to HPWR for external peripherals? on Wed, 30 Oct 2019 06:52:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi<br />
I think best way is to power them separetly from M5Stack while using same ground line.</p>
]]></description><link>https://community.m5stack.com/post/6204</link><guid isPermaLink="true">https://community.m5stack.com/post/6204</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Wed, 30 Oct 2019 06:52:08 GMT</pubDate></item></channel></rss>
