<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5STICK OLED cant turn on]]></title><description><![CDATA[<p dir="auto">My M5stick C arrived. Plugged the USB and saw led blinking. Updated the firmware via m5burner and now cant switch it on. Led also does not blink. m5 burner and arduino can detect it. I can upload the code. but screen is off. Can anyone help?</p>
]]></description><link>https://community.m5stack.com/topic/1454/m5stick-oled-cant-turn-on</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:33:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1454.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Nov 2019 21:30:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Thu, 09 Jan 2020 09:18:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ftoure" aria-label="Profile: ftoure">@<bdi>ftoure</bdi></a> hetzer was referring to the original M5Stick not the M5stickC.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/hetzer" aria-label="Profile: hetzer">@<bdi>hetzer</bdi></a> did you manage to do what you wanted with it. I find it's better to work with original M5Stick as the M5stick didn't have much functionality in UIflow even when it was supported</p>
]]></description><link>https://community.m5stack.com/post/6943</link><guid isPermaLink="true">https://community.m5stack.com/post/6943</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 09 Jan 2020 09:18:18 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Wed, 08 Jan 2020 08:49:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a></p>
<p dir="auto">Version 1.4.2 and version 1.4.3 works as well.<br />
One mistake I made and probably some others made is that you have to select the StickC version in MBurner. Also, only the 115200 speed was working properly. With the other speeds, I had "A fatal error occurred: Timed out waiting for packet header". Once the new firmware is flashed, disconnect the cable and reset the board by connecting the Gnd and the Bat connectors with a wire jumper.<br />
<img src="/assets/uploads/files/1578473299521-m5stickc-resized.png" alt="0_1578473297944_M5StickC.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/6931</link><guid isPermaLink="true">https://community.m5stack.com/post/6931</guid><dc:creator><![CDATA[ftoure]]></dc:creator><pubDate>Wed, 08 Jan 2020 08:49:46 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Tue, 12 Nov 2019 10:21:46 GMT]]></title><description><![CDATA[<p dir="auto">ah so it was 1.2.3 they dropped support. Now this gives me some point of reference as I had forgotten which version it was.</p>
]]></description><link>https://community.m5stack.com/post/6342</link><guid isPermaLink="true">https://community.m5stack.com/post/6342</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 12 Nov 2019 10:21:46 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Tue, 12 Nov 2019 10:19:40 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately M5Stack decided to drop support for the original M5Stick after version 1.2.3 without telling anyone. Firmware version 1.2.3 and below use a different fork of micropython, namely loboris's fork <a href="https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo</a></p>
]]></description><link>https://community.m5stack.com/post/6341</link><guid isPermaLink="true">https://community.m5stack.com/post/6341</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Tue, 12 Nov 2019 10:19:40 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Mon, 11 Nov 2019 17:40:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hetzer" aria-label="Profile: hetzer">@<bdi>hetzer</bdi></a> arg no it doesn't :(</p>
]]></description><link>https://community.m5stack.com/post/6330</link><guid isPermaLink="true">https://community.m5stack.com/post/6330</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 11 Nov 2019 17:40:43 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Mon, 11 Nov 2019 17:28:03 GMT]]></title><description><![CDATA[<p dir="auto">Just to confirm. I am using M5stick OLED, not M5stickC. Does latest firmware also work with M5stick OLED?</p>
]]></description><link>https://community.m5stack.com/post/6329</link><guid isPermaLink="true">https://community.m5stack.com/post/6329</guid><dc:creator><![CDATA[hetzer]]></dc:creator><pubDate>Mon, 11 Nov 2019 17:28:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Sun, 10 Nov 2019 22:05:39 GMT]]></title><description><![CDATA[<p dir="auto">It can be started by the following method.<br />
M5StickC Start Adapter<br />
<a href="https://macsbug.wordpress.com/2019/07/09/m5stickc-start-adapter/" target="_blank" rel="noopener noreferrer nofollow ugc">https://macsbug.wordpress.com/2019/07/09/m5stickc-start-adapter/</a><br />
<img src="/assets/uploads/files/1573423488044-p4_r-2.jpg" alt="0_1573423487731_p4_r-2.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/6313</link><guid isPermaLink="true">https://community.m5stack.com/post/6313</guid><dc:creator><![CDATA[macsbug]]></dc:creator><pubDate>Sun, 10 Nov 2019 22:05:39 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Sun, 10 Nov 2019 21:21:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hetzer" aria-label="Profile: hetzer">@<bdi>hetzer</bdi></a></p>
<li>Turn M5StickC off</li>
<li>Remove USB C from M5StickC. (If plugged.)</li>
<li>Connect BAT and GND pins together with a jumper wire (male to male).</li>
<li>Plug USB C into M5StickC and finally ...</li>
<li>Remove immediately jumper wire.</li>
<p dir="auto">Your M5StickC will now work as expected !</p>
<p dir="auto">Do this every time M5StickC battery is drained because of bad HW design. :-(</p>
]]></description><link>https://community.m5stack.com/post/6312</link><guid isPermaLink="true">https://community.m5stack.com/post/6312</guid><dc:creator><![CDATA[amidarius]]></dc:creator><pubDate>Sun, 10 Nov 2019 21:21:49 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Sun, 10 Nov 2019 06:57:08 GMT]]></title><description><![CDATA[<p dir="auto">I'm not sure whats wrong there as I have 1.4.1 StickC running on both of mine.</p>
]]></description><link>https://community.m5stack.com/post/6307</link><guid isPermaLink="true">https://community.m5stack.com/post/6307</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 10 Nov 2019 06:57:08 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Sat, 09 Nov 2019 21:07:21 GMT]]></title><description><![CDATA[<p dir="auto">I erased the firmware a couple of times and managed to have it working with firmware version 1.2.3. Other versions did not work. Am I doing sth wrong or m5strick oled is only working with version 1.2.3<br />
I am using windows 10 and uiflow.</p>
]]></description><link>https://community.m5stack.com/post/6306</link><guid isPermaLink="true">https://community.m5stack.com/post/6306</guid><dc:creator><![CDATA[hetzer]]></dc:creator><pubDate>Sat, 09 Nov 2019 21:07:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5STICK OLED cant turn on on Sat, 09 Nov 2019 08:00:52 GMT]]></title><description><![CDATA[<p dir="auto"><s>May sound stupid but,<br />
Q1 - You did erase the firmware first?<br />
Q2 - You made sure that the firmware version was set to stick and not stackEN?<br />
Q3 - you did make sure the baud rate was correct?<br />
Q4 - Did M5Burner show any messages?</s></p>
<p dir="auto"><s>If you did all this, try connecting to to arduino, write a demo to the stickC and then go back to burner and try rewriting the firmware.</s></p>
<p dir="auto">Okay, that is wierd, if its not detected then something is strange What OS are you using as I have forgotten.</p>
]]></description><link>https://community.m5stack.com/post/6300</link><guid isPermaLink="true">https://community.m5stack.com/post/6300</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 09 Nov 2019 08:00:52 GMT</pubDate></item></channel></rss>
