<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I&#x27;m going to play with BugC,]]></title><description><![CDATA[<p dir="auto">I have some troubles.</p>
<li>I2C command have no document (or Arduino sample is required)</li>
<li>M5StickC and BugC "BAT" pin conflict</li>
<p dir="auto">If there is a solution, I'm happy.</p>
]]></description><link>https://community.m5stack.com/topic/1459/i-m-going-to-play-with-bugc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:29:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1459.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Nov 2019 05:55:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I&#x27;m going to play with BugC, on Mon, 02 Dec 2019 01:11:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbe01025" aria-label="Profile: tbe01025">@<bdi>tbe01025</bdi></a></p>
<p dir="auto">BugC Arduino Example</p>
<p dir="auto">Github:<a href="https://github.com/m5stack/M5StickC/tree/master/examples/Hat/BUGC" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5StickC/tree/master/examples/Hat/BUGC</a></p>
]]></description><link>https://community.m5stack.com/post/6583</link><guid isPermaLink="true">https://community.m5stack.com/post/6583</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 02 Dec 2019 01:11:00 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m going to play with BugC, on Sun, 01 Dec 2019 23:43:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbe01025" aria-label="Profile: tbe01025">@<bdi>tbe01025</bdi></a> Thanks, the Arduino sample code.</p>
]]></description><link>https://community.m5stack.com/post/6581</link><guid isPermaLink="true">https://community.m5stack.com/post/6581</guid><dc:creator><![CDATA[tbe01025]]></dc:creator><pubDate>Sun, 01 Dec 2019 23:43:02 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m going to play with BugC, on Wed, 13 Nov 2019 01:19:34 GMT]]></title><description><![CDATA[<p dir="auto">Tried again.<br />
Insert the BugC battery and turn on power.<br />
On another M5StickC, screen blacked out.</p>
<p dir="auto">It seems that the problem has been solved by extending the pin socket and removing only the BAT pin.</p>
<p dir="auto">How about BugC's BAT connected to 5VIN of M5StickC.<br />
But requires 16340 charger.</p>
<p dir="auto">The LED control method is unknown.</p>
]]></description><link>https://community.m5stack.com/post/6356</link><guid isPermaLink="true">https://community.m5stack.com/post/6356</guid><dc:creator><![CDATA[tbe01025]]></dc:creator><pubDate>Wed, 13 Nov 2019 01:19:34 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m going to play with BugC, on Mon, 11 Nov 2019 12:46:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a><br />
Thanks,<br />
It matches the markings on the battery box.<br />
If I get another M5StickC,I try again.</p>
]]></description><link>https://community.m5stack.com/post/6325</link><guid isPermaLink="true">https://community.m5stack.com/post/6325</guid><dc:creator><![CDATA[tbe01025]]></dc:creator><pubDate>Mon, 11 Nov 2019 12:46:30 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m going to play with BugC, on Mon, 11 Nov 2019 10:35:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbe01025" aria-label="Profile: tbe01025">@<bdi>tbe01025</bdi></a> could you check out your battery direction is it right or not</p>
]]></description><link>https://community.m5stack.com/post/6322</link><guid isPermaLink="true">https://community.m5stack.com/post/6322</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 11 Nov 2019 10:35:19 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m going to play with BugC, on Mon, 11 Nov 2019 08:36:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a><br />
Thank you.</p>
<p dir="auto">I found the motor control similar to "BeetleC".<br />
I don't know if it is correct.</p>
<p dir="auto">M5StickC screen is confused when a battery is inserted into BugC.<br />
Is there any reverse flow from the battery on BugC side to the BAT output of M5StickC?</p>
]]></description><link>https://community.m5stack.com/post/6320</link><guid isPermaLink="true">https://community.m5stack.com/post/6320</guid><dc:creator><![CDATA[tbe01025]]></dc:creator><pubDate>Mon, 11 Nov 2019 08:36:20 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m going to play with BugC, on Mon, 11 Nov 2019 06:11:43 GMT]]></title><description><![CDATA[<p dir="auto">hi , the "BAT" pin was not conflict.   the BugC Arduino example at present we not provide.</p>
]]></description><link>https://community.m5stack.com/post/6319</link><guid isPermaLink="true">https://community.m5stack.com/post/6319</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 11 Nov 2019 06:11:43 GMT</pubDate></item></channel></rss>
