<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How many sensors can be hooked up to Port B Grove HUB?]]></title><description><![CDATA[<p dir="auto">I have a noobie question.  I just got the M5Go kit.  So I attached the Grove HUB that it came with to PortB.  To the HUB, I attached the PIR sensor unit (using pin 36) and the RGB unit (using pin 26).  I modified the example PIR.ino code to make a beep sound when motion is detected and to also light the RGB LED.  It works great.</p>
<p dir="auto">But now I'm wondering what else I could hook up to the HUB?  There is another empty socket.  Since there are only 2 pins in Port B, I really can't hook up anything else (unless I wanted to hook up a duplicate sensor unit that reacted the same way), right?</p>
]]></description><link>https://community.m5stack.com/topic/1490/how-many-sensors-can-be-hooked-up-to-port-b-grove-hub</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 07:57:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1490.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Nov 2019 14:52:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How many sensors can be hooked up to Port B Grove HUB? on Wed, 20 Nov 2019 21:35:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/happy-hippo" aria-label="Profile: happy-hippo">@<bdi>happy-hippo</bdi></a> Correct. In order to connect more you need to use the PbHub.</p>
<p dir="auto">As you have discovered, sensors use 1 pin and actuators use the other pin.</p>
]]></description><link>https://community.m5stack.com/post/6462</link><guid isPermaLink="true">https://community.m5stack.com/post/6462</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 20 Nov 2019 21:35:50 GMT</pubDate></item></channel></rss>
