<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Com port for M5Stick-C on Windows unable to be detected]]></title><description><![CDATA[<p dir="auto">When I plugged in the M5STick-C in USB mode, the PC states that it does not recognise the device and does not configure it as a valid com port.<br />
I tried installing the windows driver from the website with the same error. Am I missing something here?</p>
]]></description><link>https://community.m5stack.com/topic/1512/com-port-for-m5stick-c-on-windows-unable-to-be-detected</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 16:22:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1512.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Nov 2019 22:06:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Com port for M5Stick-C on Windows unable to be detected on Sat, 30 Nov 2019 09:49:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sirfonzie" aria-label="Profile: sirfonzie">@<bdi>sirfonzie</bdi></a><br />
1, try turning the USB lead upside down when plugging into the M5StickC<br />
2, Try a different lead.<br />
3, try a different computer (just to test)<br />
4, follow the removal and install procedure that I have posted in the forums exactly as I have written without skipping steps.</p>
<p dir="auto">The driver is very fussy and windows is also very fussy when installing and initial configuring the M5StickC and driver.</p>
]]></description><link>https://community.m5stack.com/post/6545</link><guid isPermaLink="true">https://community.m5stack.com/post/6545</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 30 Nov 2019 09:49:35 GMT</pubDate></item><item><title><![CDATA[Reply to Com port for M5Stick-C on Windows unable to be detected on Fri, 29 Nov 2019 22:46:50 GMT]]></title><description><![CDATA[<p dir="auto">Try to use other usb cable. In past i have problems with cables with come in the box.</p>
]]></description><link>https://community.m5stack.com/post/6544</link><guid isPermaLink="true">https://community.m5stack.com/post/6544</guid><dc:creator><![CDATA[OyczE]]></dc:creator><pubDate>Fri, 29 Nov 2019 22:46:50 GMT</pubDate></item></channel></rss>
