<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[USB Mode]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">i have ordered a M5Stack IoTKit.<br />
It is a makerfactory kit.</p>
<p dir="auto">I want to use local flow ide, but there is no USB mode available.</p>
<p dir="auto">Only Wifi Connection possible, no entry USB Mode on M5Stack Core :-(</p>
<p dir="auto">How can  I enter USB Mode?<br />
i can not flash firmware with burner, USB connection not working.</p>
<p dir="auto">Can anybody help me?</p>
<p dir="auto">Regards</p>
<p dir="auto">Marc</p>
]]></description><link>https://community.m5stack.com/topic/1536/usb-mode</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 15:27:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1536.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Dec 2019 07:27:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to USB Mode on Wed, 11 Dec 2019 08:22:14 GMT]]></title><description><![CDATA[<p dir="auto">you could follow this tutorial , then learn how to setup the usb mode</p>
<p dir="auto"><a href="https://docs.m5stack.com/#/en/uiflow/UIFlow_Desktop_IDE" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/uiflow/UIFlow_Desktop_IDE</a></p>
]]></description><link>https://community.m5stack.com/post/6659</link><guid isPermaLink="true">https://community.m5stack.com/post/6659</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 11 Dec 2019 08:22:14 GMT</pubDate></item><item><title><![CDATA[Reply to USB Mode on Wed, 11 Dec 2019 07:58:09 GMT]]></title><description><![CDATA[<p dir="auto">Go to M5Burner menu from UIFlow, select your device's COM port, speed should be 115200, select latest firmware available and make sure you select correct core. Reflash<br />
With every start you have couple of seconds to hit "setup" on your device and select USB Mode there.</p>
]]></description><link>https://community.m5stack.com/post/6658</link><guid isPermaLink="true">https://community.m5stack.com/post/6658</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Wed, 11 Dec 2019 07:58:09 GMT</pubDate></item></channel></rss>
