<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I2C Hub 1 to 6 with M5stickC]]></title><description><![CDATA[<p dir="auto">Could I use <a href="https://m5stack.com/products/pahub-unit" target="_blank" rel="noopener noreferrer nofollow ugc">I2C Hub 1 to 6 Expansion Unit (TCA9548A)</a> with M5stickC Grove port to connect multiple units? Seems there are different Grove port versions and isn't clear the difference in the store description and what is the one on M5stickC.</p>
]]></description><link>https://community.m5stack.com/topic/1542/i2c-hub-1-to-6-with-m5stickc</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 20:43:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1542.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Dec 2019 03:52:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Sat, 14 Dec 2019 06:29:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smh17" aria-label="Profile: smh17">@<bdi>smh17</bdi></a> yeh, the issue is the internal power regulator chip.</p>
]]></description><link>https://community.m5stack.com/post/6704</link><guid isPermaLink="true">https://community.m5stack.com/post/6704</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 14 Dec 2019 06:29:47 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 22:28:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> thanks for the answer. The missing of power specs is a serious omission, I hope M5Stack staff will add them. Do you have tried if using the hub with multiple devices attached and with USB connector of M5Stick attached to power source it changes something?</p>
]]></description><link>https://community.m5stack.com/post/6702</link><guid isPermaLink="true">https://community.m5stack.com/post/6702</guid><dc:creator><![CDATA[SMH17]]></dc:creator><pubDate>Fri, 13 Dec 2019 22:28:22 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 20:16:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smh17" aria-label="Profile: smh17">@<bdi>smh17</bdi></a> There is only the pin outs and colour codes used on current deices and which ports are used by what unit.<br />
Power specs are non existent at present, all I know from experiments is that when devices are connected to the hub, the stick suffers a "brown out"<br />
Once I finish mapping out UIFlows blocks I can continue with my hardware experiments lime getting a ammeter on the port to find out when the brownout occurs.</p>
]]></description><link>https://community.m5stack.com/post/6700</link><guid isPermaLink="true">https://community.m5stack.com/post/6700</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 13 Dec 2019 20:16:07 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 19:14:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> In the UIFlow book? In what page or paragraph. I haven't seen a specific section for Groove ports hardware specs, max power supplied on the line etc.</p>
]]></description><link>https://community.m5stack.com/post/6699</link><guid isPermaLink="true">https://community.m5stack.com/post/6699</guid><dc:creator><![CDATA[SMH17]]></dc:creator><pubDate>Fri, 13 Dec 2019 19:14:42 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 18:27:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smh17" aria-label="Profile: smh17">@<bdi>smh17</bdi></a> ah, its part of the free PDF I have uploaded</p>
]]></description><link>https://community.m5stack.com/post/6698</link><guid isPermaLink="true">https://community.m5stack.com/post/6698</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 13 Dec 2019 18:27:32 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 17:45:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> The page with the detailed specs of various Grove ports on M5stack and M5stickC.</p>
]]></description><link>https://community.m5stack.com/post/6697</link><guid isPermaLink="true">https://community.m5stack.com/post/6697</guid><dc:creator><![CDATA[SMH17]]></dc:creator><pubDate>Fri, 13 Dec 2019 17:45:27 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 14:12:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smh17" aria-label="Profile: smh17">@<bdi>smh17</bdi></a> link what? I am on a mobile phone at present</p>
]]></description><link>https://community.m5stack.com/post/6695</link><guid isPermaLink="true">https://community.m5stack.com/post/6695</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 13 Dec 2019 14:12:26 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 10:41:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Could you link it here?</p>
]]></description><link>https://community.m5stack.com/post/6691</link><guid isPermaLink="true">https://community.m5stack.com/post/6691</guid><dc:creator><![CDATA[SMH17]]></dc:creator><pubDate>Fri, 13 Dec 2019 10:41:33 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 10:19:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smh17" aria-label="Profile: smh17">@<bdi>smh17</bdi></a> if you look in the projects forum for the UIFlow roadmap discussion, I have them listed in a document. I am also going to try to make a video of it over the weekend</p>
]]></description><link>https://community.m5stack.com/post/6690</link><guid isPermaLink="true">https://community.m5stack.com/post/6690</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 13 Dec 2019 10:19:26 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 10:16:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks for the answer. Where I can check the specs of various Grove ports on M5stack and M5stickC?</p>
]]></description><link>https://community.m5stack.com/post/6689</link><guid isPermaLink="true">https://community.m5stack.com/post/6689</guid><dc:creator><![CDATA[SMH17]]></dc:creator><pubDate>Fri, 13 Dec 2019 10:16:42 GMT</pubDate></item><item><title><![CDATA[Reply to I2C Hub 1 to 6 with M5stickC on Fri, 13 Dec 2019 05:43:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smh17" aria-label="Profile: smh17">@<bdi>smh17</bdi></a> Yes, and no. Yes it will connect and work of a fashion but, no, you will need to build a power adapter cable as the StickC will struggle to provide enough power to run the hub and connected units.</p>
]]></description><link>https://community.m5stack.com/post/6681</link><guid isPermaLink="true">https://community.m5stack.com/post/6681</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 13 Dec 2019 05:43:44 GMT</pubDate></item></channel></rss>
