<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Get contents of a webpage in UIFlow]]></title><description><![CDATA[<p dir="auto">I'm trying to use the HTTP library but every single time I try to use the library I get status 200 (meaning it worked) but then when I try to use the output variable I get a "ENOMEM" error which I am assuming is "error no memory"</p>
]]></description><link>https://community.m5stack.com/topic/1553/get-contents-of-a-webpage-in-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 05:35:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1553.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Dec 2019 01:46:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Get contents of a webpage in UIFlow on Mon, 13 Jan 2020 18:06:20 GMT]]></title><description><![CDATA[<p dir="auto">I get this error in operation after a while using urequest in micropython. My impression is that it occurs less frequent when having shorter time intervals between the calls.<br />
I'm using uiflow 1.4.3 for M5Stack and the upload works but the program never starts, I have to use RUN.</p>
]]></description><link>https://community.m5stack.com/post/7019</link><guid isPermaLink="true">https://community.m5stack.com/post/7019</guid><dc:creator><![CDATA[Efried]]></dc:creator><pubDate>Mon, 13 Jan 2020 18:06:20 GMT</pubDate></item><item><title><![CDATA[Reply to Get contents of a webpage in UIFlow on Sun, 22 Dec 2019 18:17:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/jmkhello" aria-label="Profile: jmkhello">@<bdi>jmkhello</bdi></a> what kind of data are you trying to get from the webpage. This subject<br />
has been discussed in other forum posts, check these out and you may find your answer</p>
<p dir="auto"><a href="http://forum.m5stack.com/topic/1391/http-request-to-netatmo-fails-with-error-solved" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/1391/http-request-to-netatmo-fails-with-error-solved</a></p>
<p dir="auto"><a href="http://forum.m5stack.com/topic/1345/uiflow-http-request/3" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/1345/uiflow-http-request/3</a></p>
<p dir="auto"><a href="http://forum.m5stack.com/topic/1357/http-block-gives-error" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/1357/http-block-gives-error</a></p>
]]></description><link>https://community.m5stack.com/post/6761</link><guid isPermaLink="true">https://community.m5stack.com/post/6761</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Sun, 22 Dec 2019 18:17:41 GMT</pubDate></item></channel></rss>
