<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Fire and M5 Piano?]]></title><description><![CDATA[<p dir="auto">So I ordered a M5stack Fire and a M5 Piano. Now I found out that the Piano's 15 pin connector cannot fit anywhere on my M5Stack. Is there a way to convert grove to those 15 pins or is there another solution? Preferably one where I do not have to sacrifice my 600ah battery.</p>
]]></description><link>https://community.m5stack.com/topic/1575/m5stack-fire-and-m5-piano</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 05:06:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1575.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jan 2020 17:10:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Fire and M5 Piano? on Fri, 03 Jan 2020 18:52:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmroos" aria-label="Profile: mmroos">@<bdi>mmroos</bdi></a> said in <a href="/post/6868">M5Stack Fire and M5 Piano?</a>:</p>
<p dir="auto">So I ordered a M5stack Fire and a M5 Piano. Now I found out that the Piano's 15 pin connector cannot fit anywhere on my M5Stack. Is there a way to convert grove to those 15 pins or is there another solution? Preferably one where I do not have to sacrifice my 600ah battery.<br />
The Keyboard is designed for the I/O Base plate<br />
<a href="https://m5stack.com/collections/m5-base/products/battery-bottom-150mah?ref=pfpqkvphmgr" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/collections/m5-base/products/battery-bottom-150mah?ref=pfpqkvphmgr</a><br />
<img src="https://cdn.shopify.com/s/files/1/0056/7689/2250/products/BOOTOM_1200x1200.jpg?v=1566377177" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here is the know information on the keyboard.<a href="https://docs.m5stack.com/#/en/app/piano?id=pinmap" target="_blank" rel="noopener noreferrer nofollow ugc">link text</a></p>
<p dir="auto">The pins can be found on the internal 2X15 pin internal bus connection.</p>
]]></description><link>https://community.m5stack.com/post/6874</link><guid isPermaLink="true">https://community.m5stack.com/post/6874</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 03 Jan 2020 18:52:50 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Fire and M5 Piano? on Fri, 03 Jan 2020 17:36:36 GMT]]></title><description><![CDATA[<p dir="auto">get a proto  and build the 15 pins female port in it..</p>
<p dir="auto"><a href="https://www.banggood.com/M5Stack-PR0T0-BUS-Module-ESP32-IoT-Development-Board-with-215pin-Bus-Socket-Stackable-Demoboard-Protoboard-p-1264330.html?rmmds=myorder&amp;cur_warehouse=CN" target="_blank" rel="noopener noreferrer nofollow ugc">Proto stack</a></p>
]]></description><link>https://community.m5stack.com/post/6872</link><guid isPermaLink="true">https://community.m5stack.com/post/6872</guid><dc:creator><![CDATA[ChrisWR]]></dc:creator><pubDate>Fri, 03 Jan 2020 17:36:36 GMT</pubDate></item></channel></rss>
