<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Controlling the FACES II base by just connecting a serial cable ? Youtube]]></title><description><![CDATA[<p dir="auto">I have a collection of FIRE, FACE, and StickC. I am considering adding the FACES-II Base, introduced in the M5Stack channel in Youtube:</p>
<p dir="auto"><a href="https://www.youtube.com/watch?v=4DrZMttLIlM" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=4DrZMttLIlM</a></p>
<p dir="auto">Please look at the talk and video at 9:25. I do not understand what Luke meant by controlling the FACES II base by just connecting a serial cable from for example FIRE or BASIC module to the UART port of FACES-II. I checked in the <a href="http://M5STACK.com" target="_blank" rel="noopener noreferrer nofollow ugc">M5STACK.com</a> documentation of FACES-II but found nothing relevant to this point. Or maybe somebody could lead me to a certain URL or blog on this issue. Thanks in advance.</p>
]]></description><link>https://community.m5stack.com/topic/1587/controlling-the-faces-ii-base-by-just-connecting-a-serial-cable-youtube</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 02:31:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1587.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jan 2020 22:40:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Controlling the FACES II base by just connecting a serial cable ? Youtube on Tue, 14 Jan 2020 20:37:34 GMT]]></title><description><![CDATA[<p dir="auto">I don't think he means controlling the faces II base itself, I'm sure he means you can communicate with a module that uses serial comms mounted on the base using a grove cable from a separate m5stack core (with a serial port or pins).<br />
The grove port on the m5stack will supply the power for the module on the base and serial tx/rx data will be transferred over the cable instead of directly over the internal M-BUS. Which is how it will usually work with a stack of modules under a m5stack core.<br />
I'm not sure if this "remote" serial cabled comms is actually very useful in the real world.</p>
<p dir="auto">Edit: I just realised that the faces finger board uses serial (uart), so you could put a fingerprint faces board on the faces base and communicate with it over blue port c using pins 16/17 from a separate m5stack core.</p>
]]></description><link>https://community.m5stack.com/post/7046</link><guid isPermaLink="true">https://community.m5stack.com/post/7046</guid><dc:creator><![CDATA[veryalien]]></dc:creator><pubDate>Tue, 14 Jan 2020 20:37:34 GMT</pubDate></item></channel></rss>
