<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[5v supply from I2C in pogo pins]]></title><description><![CDATA[<p dir="auto">Hi every one , I have a M5fire and on the bottom module I have connected inside a BME680 (only a pressure sensor) but I have notice that the 5v on the pogo pins is only suplied by the USB-c on the charge base.<br />
I want to be supplied by the M5fire, is the a way,function to activate the 5v pin on the pogo pin ?  Thank you very much..., that issue is turn me crazy...</p>
]]></description><link>https://community.m5stack.com/topic/1597/5v-supply-from-i2c-in-pogo-pins</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 07:48:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1597.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Jan 2020 17:51:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 5v supply from I2C in pogo pins on Fri, 10 Jan 2020 18:28:04 GMT]]></title><description><![CDATA[<p dir="auto">the pogo pins are only for charging. you will need to rewire the base for what you want.</p>
]]></description><link>https://community.m5stack.com/post/6974</link><guid isPermaLink="true">https://community.m5stack.com/post/6974</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 10 Jan 2020 18:28:04 GMT</pubDate></item></channel></rss>
